It is currently Tue May 05, 2026 12:46 am
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Apr 08, 2010 4:21 pm
With that kinda help it don't matter what you get done ,,,it's a gooder day. :wink:
PostPosted: Tue Apr 27, 2010 11:11 am
That took me a while. I havent been able to access my Gmail for a week. Norton seems to be hanging it up.
PostPosted: Tue Apr 27, 2010 6:59 pm
lookin real good!
not tryin to be nosey or nothin but about how much did them front tires cost you
Brandon
PostPosted: Wed Apr 28, 2010 3:44 am
no problem ask any question i gave 80$ for both brand new they are 6 ply
PostPosted: Wed Apr 28, 2010 6:08 am
really?, where?
PostPosted: Wed Apr 28, 2010 7:40 pm
Firebug wrote:
really?, where?
X2
PostPosted: Thu Apr 29, 2010 1:17 am
i got them from a little ole tire/garage in Mt Vernon called Bill McKinney's tire! He has them in stock most of the time. Them guys call them hay rake tires.
PostPosted: Thu Apr 29, 2010 3:12 pm
I can already see a broken wrist from them front wheels with such little offset! :shock: Just warning ya, hold on to that wheel tight!
-Dakotah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Fri Apr 30, 2010 1:06 am
i hope not cant afford that koko lol. Gotta keeo workin to keep playin. I have only suffred 1 break in my time and it was my back and im only 26 years old.
PostPosted: Fri Apr 30, 2010 8:26 am
Great lookin buggy! Looks like a climber!
I'm afraid jr. is right, with the zero backspace on them front wheels, it will be an arm yanker or a steer box breaker. Been there done that. And it hurt :x . Stock vw wheels will serve you better with a stock box.
PostPosted: Fri Apr 30, 2010 8:57 am
I want a pair,, what name and numbers on the tires,, and phone number for the shop? thanks
PostPosted: Fri Apr 30, 2010 1:51 pm
thanks ky and kyjr you guys are exactly stock wheels are the best i just didnt have a descent pair so i picked this set up outta junk yard with a bunch other stuff but i will get some sooner or later i bought a set of cnc steer brakes they are dual handle thinking bout trading them in on a single.
firbebug i will gat back with you later or tomorrow i cnat remeber the brand size are 15x 5.00
PostPosted: Sun May 02, 2010 1:02 am
get me that number too if ya dont care
Brandon
Brandon
PostPosted: Wed May 05, 2010 1:34 am
Sorry fellas i finally got the # its 606 256 2060 I didnt get the brand yet but if you ask for bill and tell him you want the hay rack tires that everyone is putting on buggies he should know what you are talking about. coming to d&k from north it the exit before livingston. Exit number 59 make a right torward town go about 1 mile after you start down the big hill merge right and its 1st tire place on the left across from napa auto parts. small place country folks if you have any trouble get up with me maybe we can work out some kinda delivery to d&k or something
PostPosted: Wed May 05, 2010 8:56 am
happen to be coming to wellsville memorial day?
PostPosted: Thu May 06, 2010 1:00 am
no probley wont make that trip maybe when i get the new buggy done it will be worth taking that far from home lol
PostPosted: Sat May 08, 2010 12:34 am
kybuggy explain on the back space or off set you was talking about, like to know what to do.thanks dirtdobber.
PostPosted: Sat May 08, 2010 9:15 pm
You can put those front rims on backwards to fix the offset issue. The Stalker I bought from Aaron has the same wheels on backwards & its close to stock offset that way. Use a Dremel or die grinder to put a chamfer around the lug holes.
PostPosted: Sat May 08, 2010 10:34 pm
i actually had a lot of trouble out of my wheels hitting the calipers and had to use a spacer of about 1/8" to get them to clear. i hope i can maybe spare some cash to go back to a set of stock wheels on front but im just trying to get steer brakes and front and rear brakes together and going so money is tight also am building a new motor for this one. Wife doesnt want me to strip our 2 seater to build this one so makes the procces even slower. Tokico needs to give me a raise lol!!!!!!!
PostPosted: Mon May 10, 2010 1:08 pm
Thats a very good idea!
He might wanna check to make sure calipers clear the spokes on the wheels when he flips them. Those wheels appear to be dished to the outside a little n they may hit the outer edge of the caliper.
Stock vws have very little backspacing to the wheels. The center of the rim is pretty much vertically inline with the wheel mounting surface of the drum (or rotor). When you put on a front wheel with backspacing to it, and you use stock vw steering components, everything you hit has more leverage to fight against you to try and turn the wheels, therefore trying to turn the steering wheel out of your hand.
PostPosted: Tue May 11, 2010 12:41 am
kybuggy1 you guys are great i cant wait to get this thing together n ride with yall if i had likw 2500 bucks i might could finish but you know how that is. the closer you get the more stuff you realize you have not even thought about yet
PostPosted: Tue May 11, 2010 2:04 am
I know exactly what you mean. I've built four from the ground up and still dont know how to plan for everything in advance. Best rule of thumb for me is figure what I think a project will cost, then double it :wink: .
Gittrdun soon as u can. Lookin forward to checkin it out in person!
PostPosted: Tue May 11, 2010 10:34 am
kybuggy1 are you a fan of the dry sump Ive heard both sides. Some people say its not worth the extra weight and is un necessary. I know a lot of people recommend it around london and d&k. I really dont understand the concept of it. well just asking anyway.
PostPosted: Tue May 11, 2010 1:42 pm
I believe they are absolutely necessary if you gonna do much hillclimbing at all.
The big pump (bugpack, arpm) is like an insurance policy for your engine, IMO.
