It is currently Tue May 05, 2026 4:02 am
PostPosted: Sat Mar 13, 2010 3:29 pm
Anyone ever use a dry sump or 2-stage pump's 2nd stage for power steering? results? I have also heard of connecting the power steering lines together and install an air valve then pressurize the system (using no pump). Anyone try this?
Eric
PostPosted: Sat Mar 13, 2010 5:09 pm
Where did you hear that from? I do know that if you buy a stage 2 pump, oil will come out from the pickup tube to both outfeeds on the pump and it has only 1 infeed (scavenger line) I dunno, it may work if its got its OWN stage like in and out only, nothing from the engine at all.
PostPosted: Sun Mar 14, 2010 7:23 am
You need at least 1000 PSI for power steering. A dry Sump pump will not produce no were near that pressure. Its designed to handle a few hundred PSI max. You can however buy a dry sump pump with the ability to attach a power sterring pump to the other end for direct drive.
cron
