It is currently Sun May 03, 2026 10:56 pm
 Post subject: Limit straps
PostPosted: Mon Feb 01, 2010 1:50 pm
I know you guys said someone makes these good and inexpensive, but can't find it. A little help would be appriciated. I need 21" straps
 Post subject: Re: Limit straps
PostPosted: Mon Feb 01, 2010 1:53 pm
I believe it's David Hill, he lives in Ga but I think he only rides with the ky boys, holla at one of them!
PostPosted: Mon Feb 01, 2010 7:50 pm
Got 20" if that would work.
PostPosted: Mon Feb 01, 2010 8:02 pm
Where I need to mount is 20.5 at full droop. And the axels slide fine at that point. So I don't wanna shorten it that much.
PostPosted: Mon Feb 01, 2010 8:11 pm
David Hill 478-808-7255 Heck of a good guy!!! Makes them to what ever speck you want.
PostPosted: Mon Feb 01, 2010 9:56 pm
You'll want to shorten it a bit. If its 20.5" at full droop you should take about an inch away. Are you planning on running any adjustable clevises? they will allow you to "dial it in"
PostPosted: Mon Feb 01, 2010 11:07 pm
None at the moment Adam.
PostPosted: Mon Feb 01, 2010 11:42 pm
for one, the 20" will almost be gauranteed to stretch some, so i say you'd be good with those from gary. two, make adjustable clevises, i think i have under 7 dollars in mine... go get two big eyebolts from the hardware store (mine are even cheap grade 3 i think), take a saw zaw blade, and cut right where the eye is split from threaded side, this will give you just enough room to slide in the strap end, then weld that slot back up that you cut, run one nut on the bottom and double nut or nylock the top and walah you have cheap adjustable clevises that will last (i've been running them sincce june 08...)
PostPosted: Tue Feb 02, 2010 12:01 am
Me being cheap, I use 1/4 chain ran through an english bicycle tube, so it doesn't rattle.
It's adjustable using 6" section of threaded rod welded to the chain, that is ran through a small piece of tubing welded to the frame, it's been that way for 9 yrs.
PostPosted: Tue Feb 02, 2010 12:40 pm
i used the coated cable they sell at lowes with cable clamps very cheap never stretch and adjust them to any exact size...
PostPosted: Tue Feb 02, 2010 1:09 pm
Take a look at these adjusters. They are basically what the high dollar units are.:
http://www.mcmaster.com/#clevises/=5n7jic
PostPosted: Wed Feb 03, 2010 12:14 pm
Well Monday I called Larry, against my better judgement :roll: , and he gave me David Hills #. I called and told him what I needed and he said it would take a cpl days. When I asked how much, he said he would let me know when completed. Then all the different ideas came along, lol. Well today UPS Man showed up with a pair of straps. So I figured I call David and see if he would like paid. I won't say what they cost me, but I couldnt have beat the price + shipping at the junkyard. Too bad we live so far apart, I'd really like to thank him in person with a beer or 12. Thanks again David.
PostPosted: Tue Jun 15, 2010 3:43 pm
ordered custom limit straps from David Hill
all I can say is: quality, speedy and awesome pricing
