It is currently Mon May 04, 2026 9:27 am
 Post subject: what and where to buy
PostPosted: Mon Jan 18, 2010 7:43 pm
okay first off sorry for bombarding your fourum with new threads so often, just tryin to make surei get everthing right the first time around.i have a few questions about what to buy. first i have a 2000cc engine,
what size, and what kind of carb should i run, 1 or 2? trying to stay in the 500 doller price range.
i need a distributor, heard the stock ones are junk because they use a vacume. maybe a boshe?
the buggy came with a irs tranny, i upgraded to a 3 rib 002. the cv joints will fit the irs but not the 3 rib, can i buy just the cv's, if so what size do i need, and where to buy.
last is i think im missing a seal on the main shaft of the tranny, the very out side, i can wiggle the shaft, cant find a diagram,
and im guessinhg ebay for a cheap al. tank.
what size fuel pump are you all using..? are you using a pressure regulator with that?
sorry about all the questions again,
andrew
PostPosted: Mon Jan 18, 2010 8:14 pm
Hauser you are close to drews give them a call 1888-go-drews talk to Brian or call me 812-584-7644 carbs dual 40 idf 31/2 to 4 psi & 009 dis bus t-2 or t-4 cv
PostPosted: Mon Jan 18, 2010 8:56 pm
Hey Hauser,
Please feel free to ask any questions and after you get answers, ask the question again. For every question below, you will get many different answers. Most of the answers will depend on what type of riding you plan on doing and how much money you have to spend. There are pros and cons to every solution and you need to keep on asking until you feel comfortable with your decision.
If you only have $500 bucks for everything, you will need to be trifty to get all these parts. Here are my opinions to your questions. I am sure other will chime in and probably disagree.
Q 1) As for Carbs, I run a single Weber 40 on my 2276 but almost everyone else runs duals. Mine runs fine with a single but I am sure I could get a little more power out of duals.
Q2) If you cannot afford an MSD ignition, then Boshe is your best choice.
Q3) I have never done this but I believe you can change only the CV joint on the tranny side and use your existing axles and CVs. If you change both CVs, you will need to new stub axles as well.
Q4) I do not think you are talking about your Main Shaft, I think you are referring to the nose cone bushing on the shifting rod. This can be replaced pretty easily but they are hard to find. Check with the sponsors on this site.
Q5) Check out the sponsors on this site for a gas tank or post something in the parts forum - WTB gas tank.
Q6) Again, to save costs, I use the stock fuel pump. It works fine for me and I do not need to worry about regulators, fuses or relays. I am a big fan of keeping things simple.
Good Luck and please feel free to keep asking questions.
PostPosted: Mon Jan 18, 2010 8:59 pm
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT
is that a good distributor, or just stick with the regular 009 bosh?
and i also was just lookin around, and found this http://cgi.ebay.com/ebaymotors/Dual-44mm-Carb-Kit-Volkswagen-Dune-Buggy-Sand-Rail-77_W0QQcmdZViewItemQQhashZitem3efa40e480QQitemZ270486529152QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories you said dual 44's but that says up to 1800cc?
PostPosted: Mon Jan 18, 2010 9:06 pm
thanks mickey,
i didnt no i could use a single carb on a dual port, since your enggine is a little bigger i guess i could just go your route and get a single 40. i found a 13 gallon tank on ebay for 40.00. and if i can what msd should i get. btw thanks for your help and to all others, tonight i finally got my tranny and engine mounted up, now ready for the first start up. after i buy all the goodies :lol:
PostPosted: Mon Jan 18, 2010 10:30 pm
I am a big fan of buying quality parts. I have had to throw away to mush EMPI crap. I will not buy anything EMPI again. Carbs are a personal thing, I like Weber Carbs. They are easy to adjust and rejet.
As for the Distributor, I do not know anything about "Hot Spark". I have heard good things about Pertronix but I have never used one. The MSD Ignition will cost around $500 for the Ignition Box, Coil and Distributor.
If you give Tim a call at Southern Buggies, he can hook you up with all the parts you need. Look at the Sponsor tab to get his info.
PostPosted: Tue Jan 19, 2010 12:28 am
what trailing arm r u using
PostPosted: Tue Jan 19, 2010 7:46 pm
Carbes dual 40 idf weber or empi for a single most have best luck with a idf 44 where at in cin are you
PostPosted: Tue Jan 19, 2010 7:48 pm
west chester, 20 mins north of cincy,, can you send me a link of the weber 40 by anychance, also i been googling oil relocation kits, i cant find shit, what gives?
PostPosted: Tue Jan 19, 2010 7:51 pm
call me 812584 7644
PostPosted: Tue Jan 19, 2010 7:54 pm
cb performance is a good place to look red line webers ? & empi but like mickey said watch for junk from all
PostPosted: Wed Jan 20, 2010 12:08 am
k sellin the type 4. just got a good deal on a running type1, need carbs and clutch. any ideas?
PostPosted: Wed Jan 20, 2010 1:14 am
X
PostPosted: Wed Jan 20, 2010 10:57 am
I have a 3 rib bus tyranny and a sedan tyranny, is there a starter out there so I can run one starter for both trannys in a type 1
PostPosted: Wed Jan 20, 2010 11:16 am
They should use the same starter if the flywheel and starter bushing is the same,,,If you use an automatic starter then it don't matter about the bushing.
PostPosted: Wed Jan 20, 2010 7:07 pm
Starter will work for 3 rib or sedan what size eng dual 40idf will work 1600 & up clutch ? i like kennedy stage 1 & pressure plate & stock t- rigid disc works good but you cant slip it much .A 4 puck will take more sliping but harder on trans & cv
PostPosted: Thu Jan 21, 2010 10:00 am
It's 1600 with epi heads and a mild cam. So dual 40 will work
PostPosted: Thu Jan 21, 2010 2:54 pm
If you live in westchester Drews is 5 minutes away call Brian or Lisa
"Giv'er hell!
PostPosted: Thu Feb 04, 2010 10:58 am
I like to support my local suppliers. They are not always the cheapest, but they must make a profit too. This helps to insure that they will be there when you REALLY need them to be.
PostPosted: Thu Feb 04, 2010 6:21 pm
this is also true especially when u need something on a sat or sun and the guy will meet u at his shop and get u what u are in desparate need of to be able make a ride.....however i do try to spread my money around when im not in a hurry for something
PostPosted: Thu Feb 04, 2010 10:12 pm
I do a litte work for Drews time to time & yes they have meet me at the shop or at the race track :lol:
