It is currently Tue May 05, 2026 1:59 am
 Post subject: Trans mounts
PostPosted: Tue Oct 13, 2009 8:14 pm
I am ready to start building the trans mounts for my wifes buggy and I am running 2x3 arms and have a couple of questions to ask
How far do most of you move the engine and trans back ( 3 rib )to take some of the Angle out of the axles ? I am thinking 1 3/4 ' to 2" if the exhaust will still clear the frame at the rear .
How much is yalls trans tilted ?
 Post subject: Re: Trans mounts
PostPosted: Tue Oct 13, 2009 9:19 pm
Why would you do that? The pupose of 2x3 is to put weght on the front, it defeats the puose to move the motor back.
PostPosted: Tue Oct 13, 2009 9:22 pm
me bobby had to move johnnys back 1 in. but he is running 5 x 6 arms,it had to much angle on the axles
PostPosted: Tue Oct 13, 2009 10:57 pm
I under stand that but it seems like the angle on the axles is a little too much . I left the mounts in the stock location on my buggy and it seems they are angled back alot and I know some guys move theirs back some and I was curious how much .
PostPosted: Wed Oct 14, 2009 12:55 am
Alot of Bee Line frames use to come with a spacer right on the end of the horns when he knew you were running 2 x 3, i think it was about 1.5 inches. 2x3's aint all about moving weight to the front, everybody aint running a suuubaaaruuu :mrgreen: Drilled valves aren't the only secret them boys in ky got... :shock: I'm not sure about how much tilt.
John 3:16
PostPosted: Wed Oct 14, 2009 6:37 pm
I think the object of extended arms is more travel :D
Back in the day when I ran 3x3 I did not have enough weight over the tires ...so the cars running bus axle's hooked better
