It is currently Tue May 05, 2026 3:29 am
Post new topic Reply to topic  [ 120 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu Aug 27, 2009 8:51 am
Yeah No Shit! :roll:
PostPosted: Thu Aug 27, 2009 10:41 am
DVS1 wrote:
Maybe we should call you "Captain Overkill"? Lookin sweet!
My wife calls me the same thing! :mrgreen:
PostPosted: Fri Aug 28, 2009 4:39 am
kybuggy1 wrote:
Maaaan, if that aint the pot callin the kettle black..... :mrgreen:
Yea I'm with ya on that 1 Larry lol
PostPosted: Fri Aug 28, 2009 6:47 am
chris38375 wrote:
i would like to see more pics of the tank top
me too lol hot and works in the shop
PostPosted: Wed Sep 23, 2009 8:03 am
Been working on the steering, and it is coming together as planned (I love it when a plan comes together)! :mrgreen: I'm goin for homemade power steering
I've got some tie-rod clearance issues to work out yet... but its showing signs of progress
PostPosted: Wed Sep 23, 2009 12:46 pm
Is that an all hydrolic system? No gearing?
PostPosted: Wed Sep 23, 2009 3:23 pm
Yup. Its a bunch of parts I have been saving from fork lifts that I've scrapped.
PostPosted: Wed Sep 23, 2009 6:59 pm
LOOKING GOOD
PostPosted: Wed Sep 23, 2009 9:20 pm
how do you steer without the motor running?
PostPosted: Wed Sep 23, 2009 9:27 pm
i was wondering that myself.
lets just ride
PostPosted: Wed Sep 23, 2009 10:40 pm
cuttin brakes! :lol:
PostPosted: Wed Sep 23, 2009 10:46 pm
A lot of orbital valves used for hydraulic steering have a manual override in them in case of the pump not running. You are however screwed if you break a hose.
RaceBugg... judging by the amazing work you do on your buggies I am guessing you are set with the steering, but if you need any help pm me. I design and build hydraulic systems for a living. I am already thinking of building a hyraulic drive buggy. Similar to a chaindrive, but with hydraulic motors at each wheel and no transmission.
PostPosted: Thu Sep 24, 2009 2:20 am
now that would be badazz ......no more broke trannys
PostPosted: Thu Sep 24, 2009 8:17 am
I know you can still steer a fork lift without the motor running, plus I'll just blame it on my wife if it runs into something! :mrgreen:
Thanks, ringer, I might get myself into a mess with all these mix and match parts, but I won't know untill I get a motor in it.
PostPosted: Thu Sep 24, 2009 5:47 pm
I've been toying around with that Hydro drive as well, let me know what you come up with for the wheel speed, that is where I was nervous. And RidenRace, I would personally cut out the Vertical 1" tube and Move it forward in front of the Tie rods.
PostPosted: Thu Sep 24, 2009 5:56 pm
Running a 35" tire it wouldn't be hard to reach 70 mph. Using an accumulator for supplemental flow you could get very fast off the line acceleration while keeping a variable piston pump smaller. Finding a good lightweight engine that could run at a constant rpm would be a challenge. Motorcycle engine??? It would also be easy to go from open diff to locker at the flick of a switch on the dash.
PostPosted: Thu Sep 24, 2009 7:33 pm
I was leaning towards cutters on the hydro. SKID STEER! Without the binding and torque on parts. Hook the handles to a bypass that allows the fluid to bypass the hydro motors and waalaa, lol. I think a small diesel would be good like how a bobcat runs. More efficient at a steady RPM, I think.
PostPosted: Mon Sep 28, 2009 8:23 am
Made some progress this weekend. I got the steering valve mounted, fixed the tierod clearence issues, and started screwin around with shock mount ideas in the front.
Think those shock mounts will hold up?
PostPosted: Thu Oct 01, 2009 8:00 am
Got one shock tower almost done. It only took about 6hours or so to build :shock: I'm not sure what to do with the top. Either round it off or make it pointy and sharp and dangerous :twisted:
PostPosted: Thu Oct 01, 2009 9:15 pm
very very nice! i like pointy and dangerous...
lets just ride
PostPosted: Fri Oct 02, 2009 8:05 am
Yea, mee too!!! :mrgreen:
PostPosted: Fri Oct 02, 2009 10:03 am
Looking awsome! I noticed you welded your beam to the frame. Is that Tubing over tubing on the ends? We have issues with bending 6" over beams in the Woods. I have straightend mine out however as metal has memory it does not take much of a hit to re beand it. Are you using 4140 or some grade of CM?
PostPosted: Fri Oct 02, 2009 1:13 pm
Thanks! I sleaved the ends of the beam about 6 inches past the ends of the arms where it usually bends when you run big arms. Its all dom I think. I can't think of the last time I had to take a beam off of my buggy, so I just weld it in for stregnth and simplicity :mrgreen:
PostPosted: Fri Oct 02, 2009 1:52 pm
I was tempted to weld mine in when I built the Buggy, however I was concerned about it bending as it has done. Have you bent one yet that has been done the way yours is?
PostPosted: Fri Oct 02, 2009 3:16 pm
I haven't bent one in 5 or so years. This is also the first time I have sleaved one. I think the way I bent the piece of 1.5" for the tie rods to drop lower and welded it as close to the end of the beam as I could will greatly reduce the chances of bending it.
