It is currently Tue May 05, 2026 6:42 am
PostPosted: Sun Aug 23, 2009 8:27 pm
Looking for some opinions...
I just swapped out my engine to a 2276 with 8:1 compression. Added a six rib tranny with a six rib started and now the buggy will not start.
When I turn the key, it turns over REALLY slow. It bump starts no problem and runs great.. but it will not start by the key. I figured it was my small 925 odyssey battery but I got the same slow turn over when I hooked up my Jeep battery.
At this point, I am guessing Starter or Timing?
PostPosted: Sun Aug 23, 2009 8:42 pm
Try a different starter if you have one. But it would not hurt to check your timing 1st. It is very easy to check, if you do not have a timing light you should be able to go to Auto Zone and use the loan a tool program.
PostPosted: Sun Aug 23, 2009 9:11 pm
Is the 6 rib starter new, or known to be a very good one? Check that initial timing, if its less than 10* BTDC, its about gotta be the starter.
PostPosted: Sun Aug 23, 2009 9:13 pm
sounds like the starter mine done the same thing it would act like the battery was soo weak that it would crank and then just make a noise got a new starter and works fine
Brandon
PostPosted: Sun Aug 23, 2009 10:05 pm
Also if the trans has sat for a long time with no starter on it make sure your bushing in the bellhousing is not corroded and causing the starter shaft to be tight and drag
PostPosted: Mon Aug 24, 2009 9:39 am
If by "bump start" you mean jumping across the solenoid on the starter, but wont start by key, its gonna be wiring between the switch and starter, or the key switch. Just my 2 cents
PostPosted: Mon Aug 24, 2009 10:12 am
Thanks everyone. I am going to see if I can borrow a starter from a local vw shop. Hopefully, that will fix the problem.
For Bump Start.. I mean get it rolling and let the clutch out..
PostPosted: Mon Aug 24, 2009 2:25 pm
i call that roll starting it but that me :twisted: :twisted: :twisted: :twisted:but it could be bad ground or bad conection at the starter
here hold my beer and watch this shit!!!!!
PostPosted: Mon Aug 24, 2009 6:07 pm
Tried a different starter and no luck... I am getting the same thing.. I will check the timing tonight.. Hopefully it is too far advanced.
PostPosted: Mon Aug 24, 2009 7:56 pm
It is amazing what proper timing will do.. I was 30 degrees advanced at idle.. Now that I set it to 8 degrees, the buggy starts right up
Thanks for all of the support
PostPosted: Mon Aug 24, 2009 10:52 pm
Glad you got it starting now, but I'm glad it gave you enough trouble that you checked that timing.
30 initial wouldve gave you about 54 total, (even more if you are running MSD dizzy with the smallest advance stop bushing!)
Could've been ALL bad if you reamed on it for a while on a hot day at 54+ degrees of advance!
PostPosted: Tue Aug 25, 2009 11:04 am
Whoda thunk it?.......... :mrgreen:
PostPosted: Wed Aug 26, 2009 9:55 pm
Glad you got goin anywho.. :D :D
