It is currently Mon May 04, 2026 12:13 am
 Post subject: transmount for 3 rib
PostPosted: Mon Jun 22, 2009 11:41 pm
somebody point me towards a good front trans mount for a 3 rib tranny.
thanks.
 Post subject: Re: transmount for 3 rib
PostPosted: Tue Jun 23, 2009 12:02 am
You looking for a nose cone mount or a mid mount? I would do both if you can.
The center piece in this picture is for bug to bus nose cone mount
Here are a few shots of a mid mounts.
PostPosted: Tue Jun 23, 2009 7:04 am
If you already have a good setup on your type 1 tranny. BerrienBuggy sells a real simple kit that provided a new nose cone bracket and two small brackets for the rear that convert your existing type 1 mount to a type 2 mount.
PostPosted: Tue Jun 23, 2009 7:36 pm
I've got these 2 pieces.... are they what i need, and do they just bolt up or are there bushings or anything that go between the tranny/plate, or plate/torsion mounts?
I'm assuming that i only need one of these 2 pieces correct. the hole spacing is a little different on them so does it matter which one i use? take a look and let me know what you think.
PostPosted: Tue Jun 23, 2009 9:01 pm
use the one on the left,jus bolt to ur nose cone on tranny and then slide it in and bolt to the torsion,but u still need all the other stuff in the pic above,might have to do some welding to install the straps,like a bolt on the horns
PostPosted: Tue Jun 23, 2009 9:42 pm
yeah, we got all the other stuff too. and yeah we'll have to weld some studs to bolt to.... who's in florence and wants to help me stick all this shit together.......FREE BEER......:)
PostPosted: Thu Jun 25, 2009 9:47 pm
I bought a bus to bug kit and it raised the 3 rib up enough I had to add another shifter box on top of my old one for my rod to be level with shifter. Here some udder stuff I found out.
Tony
Tony
PostPosted: Fri Jun 26, 2009 1:50 am
Tony
u didnt have to add another shifter box u could had jus put a slight bend in the shifting rod,or put steering u-joints on both ends and made it work
PostPosted: Fri Jun 26, 2009 8:30 pm
Putting the shifter up higher is easier on my elbow.
Tony
Tony
PostPosted: Fri Jun 26, 2009 10:32 pm
Thanks for the great info guys, now if i just had the time to implement it.
PostPosted: Thu Jul 16, 2009 4:19 pm
all right, i'm probably going to try and keep all my trans questions in this thread, just for simplicity, but if i need to start a new thread for a new question just tell me and i'll do so
So we got our 3 rib out of the corner and was looking at getting it in. and the "prongs" on the cross shaft are broke off, and the bushing on the left side is really really buggered up.. So i just ordered a new crossshaft and bushing kit from drews offroad, and i think it'll be here monday. anyways, while i'm waiting on that i wanted to ask yall if the old clutch, pressure plate, and throw out bearing off of our old swing axle willl work, or are we gonna have to buy a new setup to get the power from the engine to the tranny, all that stuff is still bolted on our 1835 and i'm hoping after the crosshaft and new bushings are in i can bolt the tranny in , and then bolt the engine right to and rock on with the next part of the project..
PostPosted: Thu Jul 16, 2009 5:08 pm
If you have the early 3 rib then yes.
If you have the late then mostly no......... :mrgreen:
Clutch disc will work for either
Early pressure plate will usually work if you remove the ring in the center.
Early TOB will not work on late setup.
Early setup:
Late setup:
Note arrow pointing to TOB guide sleeve.
PostPosted: Fri Jul 17, 2009 12:33 am
discussed the early/late with the woman at drews. and we have the early modle seems like.
she said something about some piece that was on the shaft. or something like that,
there is nothng on our shaft, or any holes to bolt anything to the shaft.... make any sense?
PostPosted: Fri Jul 17, 2009 11:06 am
The something on the shaft she speaks of is that collar the arrow points to.
Lisa probably sent you a Bugpack 5035-12 shaft and bushing kit.
Post up the part numbers when you get it.
PostPosted: Tue Jul 21, 2009 4:40 pm
you were right, it is a bug-5035-12 hd crossshaft type 2 68-70
had to use the old return spring, we couldnt get the old one. got it close once, but the snap ring shot off.
any "tricks" to getting it on, or just have to bow up with it.
