It is currently Tue May 05, 2026 12:37 am
 Post subject: WTB: 69-78 VW bug
PostPosted: Wed Apr 22, 2009 11:09 pm
Recently got a woods buggy, has the old swingarm style axle in it. I've been told the only way I can go to IRS is to completely replace the rear-end, so now I'm looking for a bug to be a donor car. As I understand it I'll need to change the transmission also as the axle are different. So if anyone has a old bug that would have the parts I need and want to part with it, pm me a price and location. Or if someone has a better way to change it over, please let me know. I have no issues with replacing the whole rear end, but if theres an easier way. . .
 Post subject: Re: WTB: 69-78 VW bug
PostPosted: Wed Apr 22, 2009 11:56 pm
instead of cutting out the whole torsion houising, buy these trailing arm mounts and weld them on.
http://www.pacificcustoms.com/mm5/merch ... e=AC530004
PostPosted: Thu Apr 23, 2009 10:25 am
Where are you located?
PostPosted: Thu Apr 23, 2009 10:15 pm
Ahh cool, didn't know they made just the mounts. That'll be helpful.
And Turbo, I'm located in Clarksville, TN
PostPosted: Fri Apr 24, 2009 1:10 am
there should be a bug shop in or around nashville,or u can order them from someone on here,look at thr sponsors at the top of the page,,2 or 3 different guys,,by the way i live down here in mcnairy co.
PostPosted: Sun Apr 26, 2009 3:11 am
Ahh cool. Yeah we actually have a place that deals with VW's here in town, but they're very proud of their parts. Too proud. Lol.
Still looking for a bug, decided I could use the front brakes off one too, as my buggy has rear only. Even though they're drum, they'll work until I have the extra funds to go disc.
PostPosted: Mon Apr 27, 2009 5:38 pm
Chances are they might be a bit higher but they will probably sell you the right part the first time.
No return shipping hassles.
On the donor car, an IRS car will have a ball joing front end if it isn't a Super Beetle.
The front brakes off that front end will likely not fit yours.
Since you have a swing axle rear, I'd almost bet your have a link pin front beam.
Those never came on an IRS car so the brakes you speak of won't work if you indeed have a link pin front.
if you have a ball joint currently............nevermind....... :mrgreen:
PostPosted: Mon Apr 27, 2009 8:11 pm
It does have the kingpin front end, and I have no issues with swappin that over to balljoint either... Lol.
PostPosted: Mon Apr 27, 2009 10:59 pm
a balljoint frontend is an inch wider than king pin or the other way cant remeber,lots of work,king pin to me is the best for rough off-road
PostPosted: Tue Apr 28, 2009 12:40 pm
You will have to clip the front of the frame where it clamps on to change it out.
Ball joint beam tubes where the torsion slats are located are further apart than a king pin.
Can't remember exactly but 1-1/2" comes to mind.
PostPosted: Tue Apr 28, 2009 1:35 pm
I'm gonna swap my king pin out for a ball joint front end. They are a bit wider (an inch or so), so I am going to cut out the top bar and replace it with one with the correct bend. I would rather have the ball joint front end because they are pretty much disc brake ready, cheap to replace ball joints, and stay tight longer. My king pin front end is a constant source of enjoyment, anytime I need anything to do I can find something it needs. :D
Aut Viam Invenium Aut Faciam!
PostPosted: Tue Apr 28, 2009 2:37 pm
I know it's not a popular option but a bus ball joint front end with some modifications is wide and strong. Use drop spindles from a ball joint type 1 and get height gain and use disc . But it's a little heavy,,,good way to add weight tot he front end if you need it though.
PostPosted: Sun May 03, 2009 4:00 am
Ok, I've acquired a 71 VW superbeetle. It has the irs, so think I'm good there. Now it has a coilspring front end, will the front brakes work off it on a kingpin setup?
PostPosted: Sun May 03, 2009 11:49 am
i dont think they will,its got a high dollar steering box on it that will last forever,and good u-joints on steering
PostPosted: Sun May 03, 2009 7:05 pm
So should I swap out the steering box and tie-rods? My buggy has the stock '67 box and linkage.
PostPosted: Sun May 03, 2009 7:18 pm
its a little bit of work but heres the best pic i got
PostPosted: Mon May 04, 2009 11:40 pm
Hmm cool, might have to pull that part out before i junk the car.
