It is currently Tue May 05, 2026 12:32 am
 Post subject: Drilled valves
PostPosted: Mon Jul 30, 2007 7:06 pm
Ok, everyone talks about them, but no one is specific to what is done, so here the questions are. What are drilled valves? How big are the holes? How many holes are there in 1 valve? Are the holes in both intake and exhaust? What are the advantages or disadvantages? And last what, and why do they make horsepower? Please help me with my ignorance to this subject.
Dave
PostPosted: Mon Jul 30, 2007 9:35 pm
:lol: :lol: :lol: :lol: I would tell you straight out but it's a D & K trade secret so for all those interested in knowing the answers to the above questions, just send me $50.00 and your heads and I will take care of them for you. By the way DVS1 sometimes ignorance is bliss. :P :P :P :P :P
PostPosted: Mon Jul 30, 2007 9:54 pm
If you sell out on us WES you know what will happen :!: :!: :twisted: "I WILL HAVE TO TELL CHARLIE" $50.00 will not do it. All I can say is it gets rid of all that bad compression, but you have to run arround 15.55/1 to make it work. But Wes you know they told us that is all we can tell :!: :!: I will ask to see what the for-sure price is for forignors/outsiders.
Thanks Bruce
PostPosted: Mon Jul 30, 2007 10:00 pm
Too late I already sent the money and heads to him. :mrgreen: :mrgreen: :mrgreen: Just kiddin. I understand trade secrets. I know alot of race motor builders that won't even let you in their shop.
PostPosted: Mon Jul 30, 2007 10:13 pm
A man can't even make an honest living anymore. Too bad Bruce, I was going to split the heads with you. :lol: :lol: :lol: :lol: :lol: :lol:
PostPosted: Tue Jul 31, 2007 1:19 pm
[quote='railridernky']A man can't even make an honest living anymore. Too bad Bruce, I was going to split the heads with you. :lol: :lol: :lol: :lol: :lol: :lol:[/quote]
Wes, you did mean to say $50 PER HOLE, right :?: :o
You was gonna split the heads??
Makin' y'all a set of them ol' drag race split ports, huh? Good idea!! :!: That ought to make them drilled valves really flow! :twisted: :lol: :roll: :lol:
Anyways, dont you gotta use Rabbit Diesel pistons when y
PostPosted: Tue Jul 31, 2007 2:42 pm
Ok Guys, drilling holes in your valves defeats the purpose of them in the first place, to seal the combustion chamber during the compression and ignition stroke. Drilling holes in them would be like having bad rings with out the oil smoke. So for now I think you guys having been smoking way to much of that Wacky Tobacky and unless you can prove me wrong with some documented Dyno testing for now your full of CRAP!
PostPosted: Tue Jul 31, 2007 3:47 pm
I think I am leaning towards Odynuck's coments!
PostPosted: Tue Jul 31, 2007 5:36 pm
I build 3,500 horsepower Blown Hemi motors that run on alcohol with 54 pounds of boost and I have built hundreds of VW hotrod motors as well as everything in between. Holes in valves sounds pretty cool. I will have to try that.
Roy :?
PostPosted: Tue Jul 31, 2007 6:14 pm
Arround 95% of the buggys that were sitting on top of the big hills/Mountians at D&K Memorial Day had them. It is the way you drill them it takes some special tools to do it. Some of the big name people that makes Heads for VWs has contacted some of the ones in Ky that does it to try and get the pattern. But they will not sell out. :twisted:
PostPosted: Tue Jul 31, 2007 7:09 pm
:evil: $$$$$$$$$$$$$$$$$$
PostPosted: Tue Jul 31, 2007 10:48 pm
You cant have a motor bigger than a 1461 otherwise drilling the valves is useless,Thats what charlie told me anyway.
aaron :lol: :lol:
PostPosted: Wed Aug 01, 2007 8:22 am
Ok, You guys insist on that this is being done then at least explain its purpose and how it works.
PostPosted: Wed Aug 01, 2007 11:44 am
It lets out the bad compression, like Bruce stated, therefore the engine spins more freely and higher rpm's are obtained. The size and pattern of the holes are crucial or you will let out too much compression. I've probably given too much info. already, so thats as specific as I can be or Charlie wont drill my next set for me.. :twisted:
Normally, only KY climbers are eligible to have this done to their engines, but Bruce is in KY so much, he was let in on it.
PostPosted: Wed Aug 01, 2007 5:39 pm
"lets out BAD compression"
Hmm, I have built many engines as well, and this does not make much sense at all. First, holes drilled into the exhaust valves would most likely cause the valve to burn very quickly (holes will get bigger, fast), especially at 15:1 CR. Holes drilled into the intake valves would allow fuel mixture/compression into the intake causing blow up through the carbs or having to re-cycle the mixture again and again. Now if the holes were REAL small, it might somehow help. It still seems like it would hurt botom-end performance, imo. I thought all compression was good, unless you have too much in the first place.
PostPosted: Wed Aug 01, 2007 6:45 pm
:lol: :mrgreen: :lol: :mrgreen: :lol: :mrgreen: :lol: :lol: :lol: :lol: :lol: :!: :!: :!:
PostPosted: Sat Aug 04, 2007 9:46 pm
yeah..must be a joke of some kind. Everyone needs to laugh once in a while..more if possible :)
PostPosted: Sun Aug 05, 2007 7:25 pm
Hill Climber
I may totally wrong but I overheard a conversation and I think the hole is drilled right through the center of the valve and through the stem. I am not an engine builder so I am just sharing what I heard. Although even a simple guy like me knows holes in valves cause compresion leaks and compression leaks are bad.
PostPosted: Mon Aug 06, 2007 7:01 pm
:eek:
PostPosted: Mon Aug 06, 2007 9:11 pm
[quote='D. Marks']I may totally wrong but I overheard a conversation and I think the hole is drilled right through the center of the valve and through the stem. I am not an engine builder so I am just sharing what I heard. Although even a simple guy like me knows holes in valves cause compresion leaks and compression leaks are bad.[/quote]
YEAH, but the rocker arm tip covers up the hole!!
PostPosted: Mon Aug 06, 2007 11:02 pm
If everyone will send me a certified check I will send you a detailed schematic on this type of valve job,no gurantee is made to the quality of the schematics,just make sure the check is good. Please mail to 1234 yourasucker lane, bullshit Alabama,12345 :lol: :lol: :lol: :lol:
PostPosted: Tue Aug 07, 2007 7:48 pm
IF YOU RUN PROPANE LIKE I DO, YOU NEED EIGHT NO. 2 PENCILS TO PUT IN THE VALVE GUIDES(TO REPLACE THE VALVES). THAT WAY YOU CAN ERASE THE BAD COMPRESSION FROM THE GOOD COMPRESSION, ALSO THE LEAD FROM THE PENCILS ACTS AS A FUEL ADDITIVE. :roll: :roll: :roll: :roll: :roll: :roll:
PostPosted: Tue Aug 07, 2007 9:32 pm
Hey Brad that was supposed to be a fultondale secret about propane and the #2 pencils dont tell all,next they will want to know about how we run chevy pistons in our vw motors with dart heads cut in half to fit
PostPosted: Tue Aug 07, 2007 9:57 pm
SHOULD I TELL THEM KENTUCKY BOYS ABOUT MY NEW BEADLOCKS AND HOW I PULLED A VACUUM ON MY TIRES SO THEY WOULD BITE HARD :eek: :eek: :eek: :eek:
PostPosted: Tue Aug 07, 2007 9:59 pm
REALLY??? I have a set of Brodix 18 degree heads can I do that to them?
