It is currently Tue May 05, 2026 7:08 am
Post new topic Reply to topic  [ 83 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat May 17, 2008 12:03 am
the blue buggy in the garage in my pictures lost 90lbs 45 off each wheel with the carbon fibers. he had 16 inch steel wheels and tubes (tube alone was 12lb). The carbon fiber wheels weigh 8lb.
"Lets go get stupid"
PostPosted: Sat May 17, 2008 3:12 am
this might be a stupid ? but what does the carbon fiber rim look like and where do i get them
the sound like a good item to look into dont meen to steel your styles but the sound good so far 8)
and price thank you
PostPosted: Sat May 17, 2008 9:21 pm
i know a few guys here in ohio that run them and they are beginning to outlaw them on dirttracks due to them exploding! so i can ask around and see if someone has a set that they cant run anymore. also i will look in my photo bucket account and see if i have a pic of my carbonfiber wheels for ya man!
kevin
Ridin' in a souped up honda is kinda like ridin' the short bus, no matter were ya go someone is lookin' at ya!
PostPosted: Sat May 17, 2008 9:33 pm
and price thank you
well here is a pic of my rims that i have the pic isnt real great kcshelby84 nut they are kinda off black and the inner half of mine from the lugnuts to the inner part of the wheel is actually aluminum so when you look at mine they are two different colors from where the carbon joins the aluminum part. i am not sure if larrys are like this cause the guy i got mine from is a lil weird but they mounted fine and held air so thats all i care bout. so hope this helps ya!
kevin
PostPosted: Mon Dec 29, 2008 11:34 pm
Bump
Plumberbill read all this about the adaptors.
PostPosted: Mon Dec 29, 2008 11:42 pm
hillaholic wrote:
Bump
thanks brad
- Sigmund Freud
- Antonio Meloni
PostPosted: Tue Dec 30, 2008 4:53 pm
Any of you guys still have the adapters i have a freind who need them. you can pm me if you do. thanks dave
PostPosted: Tue Dec 30, 2008 9:13 pm
looking for a set myself
- Sigmund Freud
- Antonio Meloni
PostPosted: Tue Dec 30, 2008 9:54 pm
Try Tim and Rhonda at Southern Buggys
PostPosted: Tue Dec 30, 2008 9:59 pm
called and left a message, haven't heard back from them. gonna try them after new years
- Sigmund Freud
- Antonio Meloni
PostPosted: Tue Dec 30, 2008 10:51 pm
i could cut you people some on the water jet something like this or come up with something you like. with deans permission of corseImage
PostPosted: Tue Dec 30, 2008 10:56 pm
make this
PostPosted: Tue Dec 30, 2008 11:00 pm
give me all the measurements you can think of.ill draw it up and see what you think. i cant turn the outsides down to a half inch though. dont have a mill or lath. could make them in 2 pcs though the middle like a spacer.
PostPosted: Tue Dec 30, 2008 11:04 pm
Here are dimensions taken from Madmikes post:
The VW 4 bolt /----------/ 4 on a 130.5mm (5.137") dia. bolt circle.
The VW wide 5 /----------/ 5 on a 210mm (8.267") dia. bolt circle.
This one I'm not 100% sure of, will check and verify.
The racing wide 5 /-------/ 5 on a 257.175mm (10.125") dia. bolt circle
PostPosted: Tue Dec 30, 2008 11:10 pm
what size holes you want in them for studs? 1/2 studs go with a .400 hole and to bolt on the vw rotor.550 think thats enough. we can tweak this a little either way. let me know
PostPosted: Tue Dec 30, 2008 11:17 pm
strength wise, i dont know which design would be best. #4 or #5 look cool to me.
- Sigmund Freud
- Antonio Meloni
PostPosted: Tue Dec 30, 2008 11:24 pm
Needs to be a corection the racing wide 5 is a 5 on a 10.250" dia bolt circle
This should have been done a long time ago, got past me.
PostPosted: Tue Dec 30, 2008 11:25 pm
i have more ideas in my head just dont have the program at home to do it. ill post them tommarrow. i can put flames in the empty spaces what about a adapter that has holes for the wide 5 vw and xl5 dirt track? any body put there adapter up to see if it can be done. make life easy on everyone that way.
PostPosted: Tue Dec 30, 2008 11:32 pm
It can be done, But to do it you must grind part of the aluminum wheel to clear the lug nuts from the VW pattern.
If your doing only 1/2" thick 6061-T6 forget the fancy stuff. The adaptors I made are 3/4" thick at it's minumum anywhere, started off as a 12.5" od, 1.125 thick solid round.
PostPosted: Tue Dec 30, 2008 11:39 pm
i can cut up to 7 inches thick. just cant turn them down as long as its flat i can do it all day long. if a person had studs in the rotors should not be a problem. lets figure this out. lets hear some more ideas
PostPosted: Tue Dec 30, 2008 11:55 pm
If you would, PM me your buisness info.
PostPosted: Wed Dec 31, 2008 12:47 am
id like to have a set of the#1and the#3 how much?
PostPosted: Wed Dec 31, 2008 2:18 am
I run some made like # 4. Had them made a couple years ago. Just flat 1/2" 6061 with 9 holes poked in it, studs in the rotors, carbon fiber wheels (soon to change to aluminum). Simple, light, strong enough. Been thru alot of crap with no problems yet.
I'd like to have another pair of # 4s to put on my wife's buggy.
PostPosted: Wed Dec 31, 2008 10:11 am
instigator, if you build them, they will buy
i'm in for a set, post or pm me with a price. the flame idea sounds good
- Sigmund Freud
- Antonio Meloni
PostPosted: Wed Dec 31, 2008 2:43 pm
From page 1
turboblue wrote:
Mike
I think the wide 5 VW pattern is a 205mm BC.
