It is currently Mon May 04, 2026 9:50 pm
PostPosted: Tue Mar 18, 2008 4:43 pm
I hate to be the barer of bad news but I told everyone I'ld let you all know if any new developments came about Wellsville. This was in todays Morning Journal newspaper. I also went to the Ohio EPA site & rumaged through & found the permits & maps also.(Here's the link for the land use map: http://www.epa.state.oh.us/dsw/401/Ohio ... _12_07.pdf ) There's alot of mixed emotions around here localy about this plant coming in. Many are saying "they'll believe it when they see it". But for now I'll remain optimistic & I'll be keeping my eyes & ears open around here.
The pits for drivers
By TOM GIAMBRONIJournal Staff Writer
Plans to reclaim a strip-mined area near Wellsville popular with dirt bike and an all-terrain vehicle enthusiasts may finally happen nearly four years after it was first proposed.
Columbiana County Port Authority Chief Executive Office Tracy Drake reported at Monday
PostPosted: Tue Mar 18, 2008 4:49 pm
Well isn't that a bunch of good and bad all wrapped into one. Good for some jobs for the area bad because of closing a riding area down. Guess you will have to keep a close eye on what happens over the next few months.
The Wild Kids
PostPosted: Wed Mar 19, 2008 12:47 am
Ok, so to my understanding there are NOT mining just bringing in silt from the Maumee. Well, Maybe more hillclimbs?
PostPosted: Wed Mar 19, 2008 8:08 am
Hill Climber
Thats what I was thinking. If they would dump that silt right here in N. W. Ohio we could have a hill!!!!
Harry S. Truman
PostPosted: Wed Mar 19, 2008 8:49 am
I heard that Silt is similar to what you would encounter in the desert and sand dunes and its like a talc power when dry. You would sink.
PostPosted: Wed Mar 19, 2008 9:20 am
[quote='Odyknuck']I heard that Silt is similar to what you would encounter in the desert and sand dunes and its like a talc power when dry. You would sink.[/quote]
so your saying that anyone that rides in this stuff would have a boat anchor with wheels :?: :lol:
- Sigmund Freud
- Antonio Meloni
PostPosted: Wed Mar 19, 2008 9:36 am
Hill Climber
So what you are saying is that I should not get my hopes up that they are going to dredge the Maumee River, dump it in one huge pile, and let me climb it with my buggy....because I would sink? I'm going back to bed.
Harry S. Truman
PostPosted: Wed Mar 19, 2008 9:40 am
I guess I'm gonna have to bring paddle tires mounted & ready to change then :?: :lol: :roll:
PostPosted: Wed Mar 19, 2008 10:15 am
Keep in mind that I have no facts to back the info up. If you read the plan they are going to fill valeys and not pilr it up. I can only assumme the valleys are to contain the Silt
PostPosted: Wed Mar 19, 2008 10:19 am
Silt
From Wikipedia, the free encyclopedia
Jump to: navigation, search
For other uses, see Silt (disambiguation).
Silt is soil or rock derived granular material of a specific grain size. Silt may occur as a soil or alternatively as suspended sediment in a water column of any surface water body. It may also exist as deposition soil at the bottom of a water body.
Silt is generated by a variety of modi capable of breaking and splitting up generally sand-sized quartz crystals of primary rocks by exploiting deficiencies in their lattice[1]. These involve chemical weathering of rock[2] and regolith, and a number of physical weathering processes such as frost shattering[3] and haloclasty[4]. However, it is mainly by abrasion through transport-processes such as fluvial comminution, aeolian attrition and glacial grinding [5] most effectively operating in semi-arid environments [6] that substantial quantities of silt are produced. Silt is sometimes known as 'rock flour' or 'stone dust', especially when produced by glacial action. Mineralogically, silt is composed mainly of quartz and feldspar. Sedimentary rock composed mainly of silt is known as siltstone.
[edit] Grain size criteria
In the Udden-Wentworth scale (due to Krumbein), silt particles range between 1⁄256 and 1⁄16 mm (3.9 to 62.5 μm), larger than clay but smaller than a sand. In actuality, silt is chemically distinct from clay, and unlike clay, grains of silt are approximately the same size in all dimensions; furthermore, their size ranges overlap. According to the USDA Soil Texture Classification system, the sand-silt distinction is made at the 0.05 mm particle size.[7] The USDA system has been adopted by the Food and Agriculture Organization (FAO). In the Unified Soil Classification System (USCS) and the AASHTO Soil Classification system, the sand-silt distinction is made at the 0.075 mm particle size (i.e. material passing the #200 sieve). Silts and clays are distinguished by their plasticity.
Silt can occur as a deposit or as material transported by a stream or by a current in the ocean. Silt is easily transported in water and is fine enough to be carried long distances by air as 'dust'. Thick deposits of silty material resulting from aeolian deposition are often called loess (a German term) or limon (French). Silt and clay contribute to turbidity in water.
The main cause of river siltation is erosion from extensive plowing of farm fields, clearcut logging or slash and burn treatment of tropical forests. When the total ground surface is stripped of vegetation, the upper soils are vulnerable to both wind and water erosion. In a number of regions of the earth, entire sectors of a country have been rendered unproductive; for example, on the Madagascar high central plateau, comprising approximately ten percent of that country's land area, virtually the entire landscape is sterile of vegetation, with gully erosive furrows typically in excess of 50 meters deep and one kilometer wide. Shifting cultivation is a farming system which sometimes incorporates the slash and burn method in some regions of the world. The resulting sediment load can cause extensive fish kills, hampering economic development.
Silt, deposited by annual floods along the Nile River, created the rich and fertile soil that sustained the ancient Egyptian civilization. This silt was depended on for this purpose. A decrease in silt deposited by the Mississippi River throughout the 20th century due to a system of levees has contributed to the disappearance of protective wetlands and barrier islands in the delta region surrounding New Orleans.[1]
PostPosted: Wed Mar 19, 2008 11:03 am
silt
2 entries found.
silt[1,noun]silt[2,verb]
Main Entry: 1silt
Pronunciation: \ˈsilt\
Function: noun
Etymology: Middle English cylte, probably of Scandinavian origin; akin to Norwegian dialect sylt beach flooded at high tide; akin to Old High German sulza salt marsh, Old English sealt salt
Date: 15th century
1: loose sedimentary material with rock particles usually 1⁄20 millimeter or less in diameter; also : soil containing 80 percent or more of such silt and less than 12 percent of clay
2: a deposit of sediment (as by a river)
- Sigmund Freud
- Antonio Meloni
PostPosted: Wed Mar 19, 2008 11:25 am
They are gonna put it there and eventually it will erode and end up in the Ohio river so what the hell's the difference?
PostPosted: Wed Mar 19, 2008 11:37 am
Sounds like the EPA would have a field day if someone else was doing this and polluting the river from run off erosion. Guess it is only a one way street.
The Wild Kids
PostPosted: Wed Mar 19, 2008 11:41 am
Hill Climber
[quote='Odyknuck']Silt
Harry S. Truman
PostPosted: Wed Mar 19, 2008 11:58 am
I dont know try a search and find out. I really dont give a "Rats Ass" ol! :razz:
PostPosted: Wed Mar 19, 2008 12:30 pm
Found it for ya Dean......... :)
PostPosted: Wed Mar 19, 2008 6:35 pm
Hill Climber
Thats cool.
Harry S. Truman
PostPosted: Wed Mar 19, 2008 10:18 pm
:lol: :lol: :lol:
Jim
D. Marks wrote:
The only time I hug trees is while I'm carring them out of the way.
PostPosted: Wed Mar 19, 2008 10:26 pm
[quote='Odyknuck']I dont know try a search and find out. I really dont give a "Rats Ass" ol! :razz:[/quote]
how bout a new site idontgiveasilt.com
or siltbuggy.com
