It is currently Tue May 05, 2026 12:38 am
 Post subject: Pissed at my buggy
PostPosted: Mon Mar 17, 2008 5:00 pm
Well for the last month I have had my buggy at the front door covered by a tarp and haven't had much time to work on it like I had planned when I brought it over to the house. Well after sitting for that long the push rod tubes middle seals started leaking and I have a puddle about 2 feet wide and 4 feet long where the oil has jelled with the water and dirt. SO I washed the concrete today hoping to get the stain off the concrete. Is there any options for push rod tubes that don't leak, well don't leak as much? There has to be 2 qts of oil wasted from the oil change I just did before I parked it.
The Wild Kids
PostPosted: Mon Mar 17, 2008 5:25 pm
are u using them sh*tty spring loaded ones?
PostPosted: Mon Mar 17, 2008 6:19 pm
Properly installed stock tubes are oil dry's worst enemy.......... :)
PostPosted: Mon Mar 17, 2008 8:02 pm
I've had good luck with the stainless tubes and silicone seals. Think the tubes are about $3 a piece. I'm sure stock tubes work just as good.
Travis
PostPosted: Mon Mar 17, 2008 9:37 pm
Yes I have those shitsy spring loaded but with the new silicon pieces. Seems that after they get hot they crack and fall apart. It really pisses me off when this thing leaks like this. There has to be a better way of doing it surely.
The Wild Kids
PostPosted: Mon Mar 17, 2008 9:38 pm
Ask Brucey,,his aint leaked since he built it :wink:
PostPosted: Mon Mar 17, 2008 9:40 pm
I have thought about just putting RTV all over the damn things, then take a hammer and beat the damn thing into submission. BUT my brain started working and I realized that would cost me more money.
The Wild Kids
PostPosted: Mon Mar 17, 2008 10:24 pm
[quote='Firebug']Ask Brucey,,his aint leaked since he built it :wink:[/quote]
That is right Firebuggy, it was built right and does not leak. Get you a set of the Autocraft push tubes and it will fix your problems.
http://www.autocraftengines.com/product4.htm
PostPosted: Mon Mar 17, 2008 10:30 pm
here is some used ones, that should work.
http://www.thesamba.com/vw/classifieds/ ... ?id=584102
http://www.thesamba.com/vw/classifieds/ ... ?id=475535
PostPosted: Mon Mar 17, 2008 11:54 pm
The Empi bare aluminum spring loaded tubes are the ones I have been running in my race motor and they don't leak a drop.Helluva lot cheaper than autocraft and they have more room inside also.I always hated two piece tubes but with the Autocraft heads I run you have to use them.I was impressed.Will run somewhere around $60-70 bucks and your done.Other than that i would run stock tubes but you have to remove the heads for that.
PostPosted: Tue Mar 18, 2008 4:44 am
Jaycee and Scat, both sell aluminum spring loaded tubes that are great quality and do not leak if installed correctly. You won't have to pull the heads to install them either.
PostPosted: Tue Mar 18, 2008 1:01 pm
i run the blue scat tubes, theyre plastic, but they work pretty good.
PostPosted: Tue Mar 18, 2008 8:29 pm
if you dumped 2 qts of oil threw your pushrod tubes i would have to say you had way to much oil in that engine. if you would have pulled your valve covers of to adj. your lifters it would have dumped out any way. when you refill it check your oil level so you dont over fill it again.
DAREK
PostPosted: Tue Mar 18, 2008 8:40 pm
They way it was parked it was at an angle and everything flowed to the low spot. I only put 4 qts in after the oil change. Shouldn't be overfilled that much if any don't you think? I have always thought that 4 to 5 qts was the max depends in if it was after an oil change. 5 being if you have an external oil filter.
The Wild Kids
PostPosted: Tue Mar 18, 2008 8:48 pm
wild kid smell that oil and see if it smells like gas i had a bud that his floats on his carbs was jacked up and mixed in with his oil. ran out looked like a lot of oil. just a guess up u get it fixed.
 Post subject: oil leaks
PostPosted: Tue Mar 18, 2008 9:08 pm
I wouldn't think a VW engine would hold 4-5 quarts without leaking, I run 3 quarts in mine. Sounds like too much oil in there too me.
Donnie
PostPosted: Tue Mar 18, 2008 9:25 pm
Not true buggyman. maybe if it was bone stock no modifcations. if it has xtra oil lines oil cooler, oil filter it will hold more. my motor holds 4 1/2 quarts and dont leek a drop.
PostPosted: Tue Mar 18, 2008 9:26 pm
[quote='pipedope']wild kid smell that oil and see if it smells like gas i had a bud that his floats on his carbs was jacked up and mixed in with his oil. ran out looked like a lot of oil. just a guess up u get it fixed.[/quote]
I have had that happen to me several years ago. I will check that out in the morning and see if that might be the case. Thanks for reminding me. , the last time I lost almost half a tank of gas that was a 50/50 mix. Can't afford to loose that much money
PostPosted: Tue Mar 18, 2008 10:12 pm
[quote='pipedope']Not true buggyman. maybe if it was bone stock no modifcations. if it has xtra oil lines oil cooler, oil filter it will hold more. my motor holds 4 1/2 quarts and dont leek a drop.[/quote]
Pipedope is right Buggyman....mine is the same here.....4.5qts of oil and never leaked a drop, do you run a remote oil filter? If you do....the filter alone will hold 1qt of oil whether you run or sit....and it takes another .5 to .75qt of oil to keep the lines full while runnin
 Post subject: Oil
PostPosted: Wed Mar 19, 2008 4:50 am
Yeah, I know but I do not run any external oil coolers, I hate them. I run a stock cooler and oil pump filter and mine holds 3 quarts. I forgot to ask if he was running an external oil cooler.
Donnie
PostPosted: Wed Mar 19, 2008 6:15 am
Oops....same here....we are running stock bus coolers also....we hate the external oil coolers too.....but running remote oil filters.
PostPosted: Wed Mar 19, 2008 7:26 am
I put 10 quarts in mine.
PostPosted: Wed Mar 19, 2008 9:05 am
Yeah Bruce you have that reserve tank and a dry sump too right.
The Wild Kids
PostPosted: Wed Mar 19, 2008 11:49 am
[quote='The Wild Kids']Yeah Bruce you have that reserve tank and a dry sump too right.
The Wild Kids[/quote]
With mine I run 3 gallons.
PostPosted: Wed Mar 19, 2008 12:22 pm
[quote='DVS1'][quote='The Wild Kids']Yeah Bruce you have that reserve tank and a dry sump too right.
With mine I run 3 gallons.[/quote]
I run near 4 gallon in mine..............we are talking about Powerstrokes right?.......... 8)
