It is currently Sun May 03, 2026 6:40 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
 Post subject: Re: Newbie26 build
PostPosted: Mon Dec 28, 2015 11:24 pm
PostPosted: Sun Jan 10, 2016 3:05 pm
I like my Rad in the rear .Scalding hot water and me don't mix
PostPosted: Sun Jan 10, 2016 10:25 pm
I didn't have room between the motor and rear cage for a radiator. Where it's at should be ok
PostPosted: Mon Jan 11, 2016 10:07 am
Hi Newbie,
I have my rad in the same spot.
It cools very well there. My fans hardly ever come on and only do when I'm not moving.
The only bad thing about this location is you will feel the heat coming from the rad when you are stopped or going slow and It does block some rearward vision.
I'm now looking at the space behind my engine were my muffler is at now.
I like madmikes setup or something similar.
I worry about stuff coming off the rear tires and hitting it and also it being as efficient being out of the air flow.
(click on pic for larger view)
PostPosted: Mon Jan 11, 2016 1:38 pm
Big radiators like yours seem to be used more for 6 or 8 cylinder motors like we see on desert racers, mud boggers and tractor pulls. Any vehicle that has air-conditioning also requires a bigger radiator.
My next Subaru off road buggy will probably have one or two small motorcycle radiators and an oil cooler. Each cooler will be mounted behind the seats for protection from rocks and mud but will be slightly higher than the water level in the engine.
Fresh air will be ducted to the radiators and each will have a thermostatically-controlled fan as well as a manual override switch (for hot summer days). Large diameter aluminum tubing will serve as manifolds to deliver coolant to and from the radiator(s). The tubing will be the same diameter as the original stock.
With undersized radiators, cleanliness is super-critical. Air-conditioning coil cleaner will keep the radiator fins clean and heat conductive:
http://www.homedepot.com/p/AC-Safe-Air- ... /100599017
PostPosted: Tue Jan 03, 2017 9:36 am
Got some more work done.
PostPosted: Tue Jan 03, 2017 11:45 pm
Looking good.
PostPosted: Wed Feb 15, 2017 11:12 am
Little more workImageImageImageImageImageImage
PostPosted: Wed Feb 15, 2017 11:14 am
Top mount on passenger bag needs adjusted to square up better to the pivot
