It is currently Mon May 04, 2026 11:16 am
Post new topic Reply to topic  [ 525 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21
PostPosted: Thu Apr 02, 2015 9:18 pm
Yahoo..I finally finished my air bag setup.
PostPosted: Thu Apr 02, 2015 9:22 pm
Good deal ! I am waiting on my torsion eliminators from Mike ...I hope the USPS hasnt lost them !
Where did you get your bump stop rubber ?
PostPosted: Thu Apr 02, 2015 9:57 pm
Can't remembet, but summit racing had them for $12.97.
PostPosted: Thu Apr 02, 2015 11:03 pm
I have the same ones got them at summit, I'm spoiled summit is 20 min from me
PostPosted: Fri Apr 03, 2015 9:10 am
Thanks I will order some .I wished we had one close here . It would be like a Mans toy store !
PostPosted: Sun Apr 05, 2015 10:53 pm
Well we have been grinding the case and trying to get the bottom end of motor together. And finishing up on the shifter too I'm so ready to finish and do some riding Image
PostPosted: Sat May 16, 2015 6:54 pm
I put mine on the dyno.....79 ponys 91 foot pounds of torque and 1650 total gross weight. Bam!! Built'er from the ground up. I did that. Your welcome.
PostPosted: Sun May 17, 2015 12:32 am
what engine?
PostPosted: Sun May 17, 2015 10:58 am
1835cc vw duel 44 webers. It's on You Tube. Crows Dyno pull 1835cc
PostPosted: Sun May 17, 2015 4:05 pm
http://youtu.be/RFWzz0aT01E
PostPosted: Sat Jun 20, 2015 11:12 pm
Got my steering wheel, shaft and r/p fixed from the wildcat trip. Now working on new shocks for the front.
PostPosted: Sun Jun 21, 2015 3:09 am
Darrin,
Finley and I had a blast riding with you Saturday night. Look forward to riding again at the next event or we will need to meet up at WindRock or Tellico.
PostPosted: Sun Jun 21, 2015 9:24 am
Dan,
I'm not going to Chocco but shooting for Rush. See ya then or maybe sooner.
PostPosted: Sun Jun 21, 2015 11:53 am
Sounds good... I will be a Choccolocco but I am not sure I am going to make Rush. I am trying to talk my wife into letting me get a new Tow Rig. So far, things are not going in my favor..
PostPosted: Sat Jun 27, 2015 7:23 pm
Installed new fronts shocks and bump stops.
PostPosted: Wed Jul 01, 2015 10:46 pm
needed a rear bumper for mine. it never had one. bought a baja rear bumper but the top arms that would normally go to the rear shock towers werent long enough. i needed mine to go to the frame. and i wanted it removable in case i need to drop the motor or trans.so i cut some 1 1/2 tubing to ad length to the top arms and built a sleeve to weld into on the bumper side that the whole bumper assembly slides onto the mounting points on the cage and tranny mount. bolts on. soon as i get everything welded up itll be really nice.going to ad a rear skid plate to it once its fitted and welded.kaz
PostPosted: Fri Jul 10, 2015 11:07 pm
"Assessed the damage" of a freakin barrel roll at Wildcat last weekend!!! :shock:
First was easy, the next 2 was hard hits to the roof and rear cage, then landing flat on all 4's. Luckily just cage damage, nothing else!
Gf and myself was belted in tight, with only a couple bruises to each of us!
PostPosted: Fri Jul 10, 2015 11:10 pm
PostPosted: Sun Jul 19, 2015 10:42 am
ImageImage.
Anyone know these boys??
PostPosted: Sat Dec 19, 2015 10:15 pm
Switched my pivot bolt washers both to the inside.
PostPosted: Wed Dec 23, 2015 6:13 pm
I replaced the flex radiator hoses with tube today
I'm finally somewhat happy with the radiator placement so i figured just do it
Before and after:
PostPosted: Wed Dec 23, 2015 6:14 pm
I have one on the outside and one on the inside, what was the reason for putting them both inside?
PostPosted: Wed Dec 23, 2015 8:09 pm
I've read they are used to move the arm in and out. This helps in the centering of transaxle in relationship to your axles.
PostPosted: Thu Dec 24, 2015 12:12 am
I have also had to move them to get more toe in adjustment
Sent from my XT1080 using Tapatalk
PostPosted: Fri Apr 15, 2016 9:53 pm
Moved my light bar down from bottom of windshield to front. Didn't like the way it lighted up the front of my buggy.
Users browsing this forum: No registered users and 7 guests
