It is currently Sun May 03, 2026 1:18 pm
Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Fri May 15, 2015 11:51 am
I make 3"drop combo spindles. If your asking if I use a stock size link/pin spindle stub, no.
I do not make micro stub rear arms, I make something I think is even better.
PostPosted: Wed May 27, 2015 11:43 am
I've ordered a fresh batch of material, front or rear arms anyone?
PostPosted: Thu Jun 11, 2015 5:28 pm
Out with the old and in with the new(er).
My old 4X7" band saw starting acting like a *itch so it became time to replace it. I've got no complaints with it, 33 years of cutting steel, time to retire it.
New(er) saw will do 8X12, see if it can last 30 years, made in the USA, I guess we'll see.
PostPosted: Fri Jun 12, 2015 7:02 am
Very nice
Sent from my XT1080 using Tapatalk
PostPosted: Fri Jun 12, 2015 9:54 am
This day in time its almost impossible to buy quality parts . But that is not a problem with Mike's parts ! They are top notch.
Usps lost my shipments from him twice but mike made it right and would not except a dime extra for his trouble.
Hard to find people like that anymore. THANKS
Sent from my LGL31L using Tapatalk
PostPosted: Fri Jun 12, 2015 4:10 pm
Your welcome. I couldn't see this ending any other way, you paid your bill and it wasn't your fault the union protected government slackers decided to "loose" your parts. The second no show is clearly my fault, knowing that doing something over and over again expecting a different result is the classic definition of stupidity. So I must of had a senior moment or a brain tumor or something trying twice, won't happen again :wink: .
PostPosted: Wed Jun 17, 2015 9:01 pm
Could it be possible to build a set of stock width x2.5 longer rear trailing arms
Just that guy
PostPosted: Wed Jun 17, 2015 10:20 pm
Just that guy
Yes I can. Not to long ago I built a set of stock width, 3" longer for a guy that had a wider than stock torsion housing.
PostPosted: Thu Jun 18, 2015 4:58 am
Ok that's basically where I'm at are the prices still the same as on the store
Just that guy
PostPosted: Thu Jun 18, 2015 11:01 am
That's correct.
