It is currently Sun May 03, 2026 2:14 pm
PostPosted: Sun Mar 01, 2015 11:46 pm
I am in the process of building a brand new SS. I am using a 5 rib trans, and would like to see some picturesand details of other shifter linkage setups. Im not really sure what route to take so im looking at all the options.
PostPosted: Mon Mar 02, 2015 12:43 am
Save up lots of money, put it in the bank and retire at 40.
PostPosted: Mon Mar 02, 2015 12:45 am
The best, cheapest and easiest way is with two small universal joints connecting the shifter to the trans if there is enough room, if not it gets "complicated".............
PostPosted: Mon Mar 02, 2015 12:01 pm
I will take a few pics when I get home today. It can be VERY simple!! I had one of those side shift linkages (not nearly as nice as madmikes) and it was a pain in the a$$! too many moving parts.
PostPosted: Mon Mar 02, 2015 10:29 pm
All help is much appreciated. I like the look of the setup madmike, but it does seem a but complicated with alot of potention adjustment issues...once it is adjusted have you had many issues with it?
PostPosted: Tue Mar 03, 2015 9:17 am
here is a pic of my race buggy.
here is a pic of kevins linkage.
PostPosted: Tue Mar 03, 2015 11:47 am
Racebugg how do they twist like that?
PostPosted: Tue Mar 03, 2015 12:56 pm
having the bend before the joint lets the weight of the shift tube always hold the shifter to the 3rd-4th side of the shift gate. kevins has quite a bit more bend to it, but works great. You would never know it was bent like that if you didn't see it. My buggy shifts better than any buggy I have ever tried. It is just as tight as a new car.
PostPosted: Tue Mar 03, 2015 1:53 pm
Wow!! I cant tell but no universal joints or anything?
PostPosted: Tue Mar 03, 2015 3:26 pm
they both have 2 joints. The red one has one on either side of the "s bend" and mine has one at the trans and after the first bend.
PostPosted: Tue Mar 03, 2015 3:46 pm
Cool! I would've lost money on a bet on that one!!
PostPosted: Tue Mar 03, 2015 5:27 pm
That is sharp. Didn't think it would work but, I may try it also
PostPosted: Tue Mar 03, 2015 5:58 pm
All right, I must have grown a brain tumor or something, I'm not seeing it. The lateral movement I get, the rotational movement I'm not getting. Those are all steel parts, no cable in there?
PostPosted: Tue Mar 03, 2015 7:30 pm
mike yours is bad ass, first off! and secondly my damn neck hurts from twistin my head back and forth tryin to figure out how they would work :lol: :lol: :lol: it seems as if it would try to raise or lower the shift fork? these are nose shift trannies correct?
PostPosted: Tue Mar 03, 2015 8:51 pm
Well I know what you all are saying and im the same way, but obviously it works cause its on two race buggys that's been around for a while. Like I said ,I would've lost money on a bet!!! The universals must play the key role ????????? :?
PostPosted: Tue Mar 03, 2015 9:39 pm
Idk blows my mind.... but I think Newton just rolled over in his grave
PostPosted: Wed Mar 04, 2015 8:52 am
its one of those things that is way to easy to overthink. they are both regular old 6 ribs. Yes it is solid tube (heavy wall). Yes it does lift and drop with rotational movement.
here is one joint connected to the trans
here is a pic from the other side. There is a small green bungee cord holding it down to help keep tension on it and keep play to one side.
PostPosted: Wed Mar 04, 2015 9:45 am
Clever setup Racebugg. Something tells me the "first gen" model of that linkage must have taken some trial and error to perfect.
PostPosted: Wed Mar 04, 2015 2:21 pm
Dont think I have ever seen those type of universals. What are they from?
PostPosted: Wed Mar 04, 2015 2:52 pm
they came from drews. I think they are for steering but Im not sure.
PostPosted: Wed Mar 04, 2015 6:35 pm
I think a video would help, I think I get it but then again still makes my head hurt, I never would thought that could work, nice
PostPosted: Wed Mar 04, 2015 8:26 pm
Yep it works grate. The joints are from Drews off road they are a ball and pin and the one on the trans is 7/8 by 1/2 and goes wright on the trans . I welded a 1/4'' nut on it to go on the trans . And there is no ajusters to come lose. I hope to have the a arm buggy at Drews swap and sale April 12
PostPosted: Sat Mar 14, 2015 11:59 pm
I'm going to follow this cause I need ideas too. My current linkage is all screwed up. Going to redo it soon.
PostPosted: Sun Apr 05, 2015 9:23 pm
Mike they use sealed ujoints like that on aircraft and the racing world caught on to them years ago but "good" ones are pricey
PostPosted: Tue Apr 07, 2015 8:17 am
Two cheap ujoints and a used connecting rod. Works great. Chad :mrgreen:
