It is currently Mon May 04, 2026 5:20 am
 Post subject: Fox ifp shocks
PostPosted: Sun Jul 13, 2014 8:37 am
Has anyone ran these before any pros and cons
 Post subject: Re: Fox ifp shocks
PostPosted: Sun Jul 13, 2014 11:02 am
I have no first hand experience with this particular shock but it seems to be a Fox emulsion shock with rubber bushings on the ends instead of heims. That being the case, there as good as anything Fox puts out.
Anyone in the market for shocks also needs to check out http://f-o-a.com/index.php
PostPosted: Sun Jul 13, 2014 1:38 pm
I just learned about these last week. IFP means independent floating piston. This is a free floating piston within the shock that seperates the nitrogen from the oil to make a more stable shock. So the gas is held in a chamber all its own. no foaming or fade. They can be added to existing fox shocks.
PostPosted: Sun Jul 13, 2014 1:45 pm
Here is a picture. upper chamber holds nitrogen and lower holds oil. Normally oil and nitrogen in the same chamber. if oil is unstable or shock gets worked rapidly the oil may foam and the shock becomes less effective. With the two in separate chambers the dampening stays more consistant.
PostPosted: Sun Jul 13, 2014 4:27 pm
We'll I think that's what I'm going to run. I run some Gabriel overload shocks now with coil spring and I do nothing but blow them out every trip
PostPosted: Sun Jul 13, 2014 7:50 pm
Nice, they are coming out with neat stuff all the time.
PostPosted: Sun Jul 13, 2014 10:36 pm
Cease. Bag up yer money for your kids college or his or her home. Don't be like I was. $400 x's 20 years in the bank is gold. Don't send California kids too college! Send yours. Yes Mike. I am behind a cold one. Click the next button. lol. I've climbed a many a cliffs in my time and there are no naked women at the top, so cease.
PostPosted: Wed Jul 16, 2014 7:53 am
It's exactly the same setup as the long bodied bilstiens, or any Foxes with remote canisters. Yes, it helps reduce fade and cavitation, but the downside is the shock body has to be longer for any given travel.
Personally I'd just buy the remotes.
PostPosted: Wed Jul 16, 2014 1:45 pm
So, once you set up for this shock, modify your shock tower or upper shock mount, your committed to this shock. Chances are nothing else will fit in there. Good insight Phillip.
PostPosted: Wed Jul 16, 2014 6:41 pm
Well, the Bilsteins might :D
PostPosted: Thu Jul 17, 2014 10:43 am
So do you guys think would be ok to run on the rear in conjunction with torsion bars
PostPosted: Thu Jul 17, 2014 12:43 pm
I am sure you could, but I agree with Philip too. Just get the regular shocks with remote cans.
