It is currently Mon May 04, 2026 10:01 pm
 Post subject: 4x4 buggy help
PostPosted: Tue Feb 25, 2014 1:13 pm
I want to build a four seat buggy with four wheel drive. The place where I am stuck is I need a way to dis-engage the front drive shaft so I can drive in 2WD like a normal buggy. I don't want a transfer case, any ideas?
 Post subject: Re: 4x4 buggy help
PostPosted: Tue Feb 25, 2014 3:41 pm
How are going to get power to front?
Fwd engine and trans turned sideways?
PostPosted: Tue Feb 25, 2014 4:04 pm
Just run a drop box like a sled puller does. not really a transfer case but more like a splitter
kydecoy
Work Hard Play Harder
PostPosted: Tue Feb 25, 2014 7:14 pm
If you use a VW Syncro 094 Trans, you can get a nose cone decoupler to disengage the front drive shaft.
I believe some of the older Subaru Trans had a disconnect as well but you would need to buy the reverse ring and pinion from subaru gears.
PostPosted: Wed Feb 26, 2014 8:25 am
Sideways FWD trans. I'd use a VW tranny, but I want one designed for more then 60HP on the street. Trying to make it durable, not just simple.
PostPosted: Wed Feb 26, 2014 8:30 am
Not sure what that is?
PostPosted: Wed Feb 26, 2014 9:27 am
I have entertained the idea of 4x4 in a buggy too, I was thinking one of these unit with out the reverse gear- http://youtu.be/mBkN3CdBtOU
PostPosted: Wed Feb 26, 2014 1:38 pm
Its made for Bikes. probably about as good an idea as putting a 50 hp tranny on a 200 hp buggy. Right basic design, just want something that last for more then 6 good rides.
PostPosted: Wed Feb 26, 2014 2:11 pm
They claim at begging of video good to 500 HP idk just a thought
PostPosted: Thu Feb 27, 2014 12:31 am
500 HP at what weight tire size and terrain? Each thing you change changes that rating. 600lb street bike wont have the load a 2500lb 4x4 buggy will in the woods on hills.
PostPosted: Thu Feb 27, 2014 7:31 am
The best thing to do would be to call the company and tell them what you're wanting it for instead of basing everything off of the video, if they recommend it and warrantee it then go for it, it's a nice design.
Sent via TapaTalk
PostPosted: Thu Feb 27, 2014 10:02 am
good point.
PostPosted: Thu Feb 27, 2014 10:13 am
Unlock the front hubs.
PostPosted: Thu Feb 27, 2014 10:57 am
If I have to park and get out to put it in 4WD I'd never put in 2WD.
PostPosted: Thu Feb 27, 2014 11:18 am
Buy a rzr 4 and be done with it :roll: :lol: 8)
PostPosted: Fri Feb 28, 2014 9:19 am
Not what I'm looking for.
