It is currently Mon May 04, 2026 5:17 am
PostPosted: Sun Dec 01, 2013 11:23 pm
I have had several problems with intake gaskets sucking in on my heads.I really got on it at rush Saturday and it happened again. Is there a better gasket or should I make my own to fix this? Has anyone else had this problem? Chad :mrgreen:
PostPosted: Sun Dec 01, 2013 11:57 pm
Iran SuperFlow heads on my buggy last year. My intake bolts would loosen and that would happen it happened a couple of times on me. Then I started putting Loctite on the intake bolts and fix the problem if they get a little bit loose that will happen
PostPosted: Mon Dec 02, 2013 12:19 pm
Leave the gaskets out and use a thin coating of permatex ultra grey. The junk paper gaskets always shrink and get brittle after a few heat cycles. The weight of the carbs makes the problem worse.
PostPosted: Wed Dec 04, 2013 5:26 pm
I'm gonna let jesse post some pics of mine lol , and you can see if thezs are what is happening to yours , I've only found one real solution to this problem ! :lol:
PostPosted: Wed Dec 04, 2013 8:43 pm
It wont let me post them ron
PostPosted: Wed Dec 04, 2013 8:50 pm
That suckz for them ! Lmao :shock: :lol: :lol: :lol:
PostPosted: Wed Dec 04, 2013 8:53 pm
Its 518 locktite flange sealent ™ ! Lol
