It is currently Mon May 04, 2026 8:22 pm
PostPosted: Wed Sep 26, 2012 8:10 am
Do any of you know anywhere that sells just the 4 center head studs to go from a single port to dp heads.
PostPosted: Wed Sep 26, 2012 8:37 am
Also thought about just making some spacers if this wouldn't cause a problem later since some of these studs have been really hard to get out.
PostPosted: Wed Sep 26, 2012 7:18 pm
8mm or 10mm? You can't use spacers because the studs will hit the intakes,unless you are building a long stroke/long rod motor then you could use the longer studs.
