It is currently Mon May 04, 2026 1:57 pm
 Post subject: coil
PostPosted: Sun Aug 12, 2012 9:48 pm
so i was out ridding today and i noticed my buggy kept getting weaker and weaker then it got to where it wouldnt run unless i kept it reved up highand it would pop and crack like it was 180 out of time then it copmpletly quit so, and wouldnt start back. and when i checked every thing i was getting some fire threw my coil but nothing like it should, im pretty sure its the coil, what is the best coil to get now ?
 Post subject: Re: coil
PostPosted: Sun Aug 12, 2012 10:15 pm
Get a super blue coil Ive had great luck out of them
PostPosted: Mon Aug 13, 2012 10:45 pm
ive had that coil on it for a lil over a year lol
PostPosted: Mon Aug 13, 2012 11:38 pm
Just a thought, VW coils should be mounted on their side, they run cooler that way.
PostPosted: Tue Aug 14, 2012 2:57 pm
it is and i got a resistor on in it too
PostPosted: Tue Aug 14, 2012 4:45 pm
Are you running points or electronics Ignition? Disconnect the coil from the distributer and then mimic operation by pulsing ground wire to motor. Does it produce a bright blue spark ? If not then replace it.
PostPosted: Tue Aug 14, 2012 9:40 pm
points, i never do have any luck out of electronic lol but yea the coil is bad, i was just woundering what would be a good one to get, i went with a bosche
PostPosted: Tue Aug 14, 2012 10:13 pm
If you have a Bosch coil you don't need an external resistor. They have one built in
PostPosted: Wed Aug 15, 2012 1:59 am
aircooled says there is 5 different "blue" coils
http://vwparts.aircooled.net/12V-Bosch- ... -012us.htm
http://www.ratwell.com/technical/BlueCoil.html
my local vw shop just ask if i got points or electronic and goes to back and gets what i need and have never had any trouble out them and i run the standard original petronix
