It is currently Sun May 03, 2026 10:54 am
 Post subject: D.U.I Distributor setup
PostPosted: Fri Nov 18, 2011 7:25 pm
Southern Buggys / WB Sponsor
I think im goin to try a D.U.I. distributor. My MSD 6AL went bad...
PostPosted: Fri Nov 18, 2011 7:56 pm
Did you check your rev limiter (white pill) if it went bad? I had a buddy with the same setup on his boat and it quit on him and he replaced it with another one just to see what happens and it fired right up, just sharing some info with you. It doesn't matter what rpm pill it is, just try it to see if it fires up and also take the white wire coming out of the box (unplug distributor first) and tap it on a good ground and see it your coil fires, either way is a good troubleshooting reference on the MSD systems.
PostPosted: Fri Nov 18, 2011 7:59 pm
Thanks for the information but i think im still going to try the D.U.I.....If i can get the same performance and not have a coil and ignition box mounted on my buggy then it would be worth the money just for the cleaner look. Hopefully less weight....HaHaHa
PostPosted: Mon Jan 16, 2012 8:44 pm
i just looked up d.u.i. thats pretty cool I didnt know they ever was such an animal. in my opinion you dont get any better than gm h.e.i. gm used it for a long time. they have an infinately adjustable timing curve. how much are you finding this for? id like to have one I was going to get a richporter pointless before i seen this.
PostPosted: Mon Jan 16, 2012 8:51 pm
Post some more info on this setup please,and where you found it.thanks.Chad :mrgreen:
PostPosted: Mon Jan 16, 2012 8:55 pm
http://www.performancedistributors.com/vwdui.htm
PostPosted: Mon Jan 16, 2012 9:03 pm
I pulled an old hei distributor out of the dust and reminded myself how big the cap is. this will not work with a single carb or a mechanical fuel pump. Otherwise this should be a great distributor.
PostPosted: Mon Jan 16, 2012 9:05 pm
Pretty cool but is there a way to setup a rev limiter on this system some how.Chad :mrgreen:
PostPosted: Mon Jan 16, 2012 9:10 pm
if this is still using the g.m. module malory makes a module with adjustable "soft touch" rev limit jegs sells them
PostPosted: Mon Jan 16, 2012 9:13 pm
http://www.jegs.com/i/Mallory/650/699/10002/-1
PostPosted: Mon Jan 16, 2012 9:14 pm
I like the idea of running this,would it interfer with dual carb linkage you think or is it same height just wider.Chad :mrgreen:
PostPosted: Mon Jan 16, 2012 9:18 pm
I wouldnt know for sure because I only have a broken solex but by lookin a pics of dual setups it looks like it would be ok
PostPosted: Mon Jan 16, 2012 9:25 pm
Thanks for the info,that's what makes this site so great,really good people posting info to help someone out.that's why I try to read every post you never to dumb to learn something new,well at least see something new anyways,lol.thanks. Chad :mrgreen:
PostPosted: Mon Jan 16, 2012 9:27 pm
And I thought it was going to be a breathalyzer for your buggy to shut it off before you passed out :shock: ,lmao.Chad :mrgreen:
PostPosted: Mon Jan 16, 2012 10:21 pm
Sorry guys, i hadn't looked at this post in a while. Looks like some of you took care of the questions for me. Thanks
PostPosted: Mon Jan 16, 2012 10:33 pm
sorry didnt mean to hijack an old post but i thought it was a great setup and then gasman lit it up with all his questions :shock: hahaha
PostPosted: Tue Jan 17, 2012 5:56 am
i had a buggy a while back with this distrubutor setup in it and it ran just fine, it had dual carbs and a electric pump on it, one of my buddys has it now and still no problem, also chris roberts from up around bruton branch tn has been running one for several year now with no problems
PostPosted: Wed Aug 22, 2012 3:25 pm
so, who has tried this, and what performance gains have you seen in comparison to a full MSD setup? Really considering one of these, but if I'm not going to gain much more performance, then I'm going MSD...
