It is currently Mon May 04, 2026 11:19 am
PostPosted: Mon Jan 09, 2012 10:13 pm
Was wondering what you side shift guys have come up with for mounting a aftermarket slave cylinder on a side shift .
Thanks for any help !
Jason
PostPosted: Mon Jan 09, 2012 10:25 pm
i havent seen one in awhile but i dint remember it being any different than a 6 rib. i got a new buggy coming on day this week i can get a pic then it has a side shift in it.
PostPosted: Tue Jan 10, 2012 2:17 am
Use a slave saver do a google search
And u have to drill and tap 2 holes but its easy I have done it on 3 diffrent ones
PostPosted: Tue Jan 10, 2012 2:27 am
does your tranny shift towards the front or a mid shift? i run a 483 mid shift and the stock slave cylinder and mounting bracket work great.. its easy to bleed and inexpensive
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Thu Jan 12, 2012 8:01 pm
VERY true. After running a cnc slave for years, I decided to try the factory push style slave. The difference is night and day. I even had an extended arm and the factory setup is still a LOT easier to push. Use factory and you will be convinced. No more binding, bypassing, leaking, hard to pull slave cylinders!
PostPosted: Thu Jan 12, 2012 8:56 pm
Jason i use a stock slave and bracket works great been there three years without a problem
PostPosted: Thu Jan 12, 2012 11:30 pm
Thanks for the help guys , I'm going to stick with the stock setup and just put new parts on .
PostPosted: Sat Jan 14, 2012 9:14 am
What stage clutch and pressure plate were you running?
Im running the cnc setup with stage 2 and its a nice firm pedal but not that bad.
