It is currently Sun May 03, 2026 9:28 pm
PostPosted: Fri Dec 23, 2011 4:31 am
whats the best way to get the collector off without destroying an other wise perfectly good pipe?
ive got the 2 front pipes out but have done everything i can think of to get the 2 back pipes out with no success :evil:
PostPosted: Fri Dec 23, 2011 8:02 am
Is it then nuts or bolts that are stuck , if so try to put heat on then and then melt candle wax or bees wax into the thread side your trying to get out . It is a great little trick that normally works !
Hope it works and good luck .
Jason
PostPosted: Fri Dec 23, 2011 9:02 am
A little bit of heat and lots of wiggling . tapping around it with a hammer . it worked for me.
PostPosted: Fri Dec 23, 2011 9:49 am
When in doubt get a bigger hammer
PostPosted: Fri Dec 23, 2011 10:14 am
x2 bfh!!!
Don't let out when in doubt!!
PostPosted: Fri Dec 23, 2011 10:20 am
Kroil, everybody should have a can, best stuff on earth.http://www.kanolabs.com/msn/
It works or you don't pay!
PostPosted: Fri Dec 23, 2011 4:46 pm
done been soaking in silikroil for 2 days
also tried a handheld propane torch last night may have to break out the acetylene :roll:
PostPosted: Fri Dec 23, 2011 4:48 pm
giveitagallon wrote:
Is it then nuts or bolts that are stuck .
Jason
no its the slip joints
PostPosted: Fri Dec 23, 2011 5:13 pm
mine is stuck too so if you figure it out let me know how lol
PostPosted: Fri Dec 23, 2011 6:58 pm
x3
PostPosted: Fri Dec 23, 2011 9:04 pm
Jason
Have seen this done,really works with nuts.
Can you twist them anyway.maybe take a long bolt or all thread and put in the spring holes and screw it out.Chad :mrgreen:
PostPosted: Fri Dec 23, 2011 11:42 pm
Jason
its a bugpack "big motor" header and its not made like a tri-mill, the spring tabs arent really mounted so that you can the bolt trick
PostPosted: Sat Dec 24, 2011 11:17 pm
thats the exact one i have i wanna put a ubend on it do they make on for this style
PostPosted: Mon Dec 26, 2011 1:57 am
never seen a u bend in that particular pipe but i want one also
why dont you see if somebody down around there can make one, there should be a muffler shop with a mandrel bender somewhere in birmingham
PostPosted: Mon Dec 26, 2011 2:36 am
good idea we have a place in town never thought about doing that
PostPosted: Mon Dec 26, 2011 9:39 pm
let me know what they charge and post a pic i may get me one made also if you can somebody to do a good job and not flatten or kink up the pipe
PostPosted: Mon Dec 26, 2011 9:42 pm
PostPosted: Mon Dec 26, 2011 10:19 pm
ok i will it will be like 2 weeks befor i do anything to it but will keep posted
PostPosted: Tue Dec 27, 2011 2:05 pm
It will hurt your power
PostPosted: Fri Dec 30, 2011 11:51 pm
Ever get these apart? Looked at mine today on the single seater and they are made like yours,believe you can make you a tool to take these apart fairly easy.Chad :mrgreen:
PostPosted: Sat Dec 31, 2011 1:18 am
yeah finally got them apart with a lot of silikroil, propane torch, 2ft. pry bar, vise, rubber hammer, elbow grease, and a LOT of sweat and choice words lol
PostPosted: Sun Jan 01, 2012 8:43 pm
clean everything up real good and coat the tubes with hi temp nickel anti sieze before you re-assemble. Also on the u bend,you can buy mandrel bends from jegs or summit.Just get the flange and weld it together.
PostPosted: Mon Jan 02, 2012 12:44 am
i had already thought about the anti seize and the pre bent tubing is a good idea
PostPosted: Thu Jan 05, 2012 4:30 am
check this out jesse
http://hardlinecrawlers.com/forums/inde ... ;topicseen
PostPosted: Thu Jan 05, 2012 9:22 am
Antiseize wont work. The exaust gets so hot that it will just burn off. Go to advance auto parts and they sale a small exaust pipe expanding tool. Use it on you collector and your problems will be solved. I use one on every exaust i install and they always come right off no matter how long they are on.
