It is currently Mon May 04, 2026 12:34 am
 Post subject: Need your help please.
PostPosted: Sun Dec 04, 2011 5:33 pm
Ok, Im wanting to upgrade to some better brake calipers, Would be able to just go buy a set and be done BUT I dual beadlocked my rims So my question is if I could get some measurements of how high different calipers you guys are running are from the outer edge of the brake rotor. Im running the cheapo ghia calipers now and have about 1/4" of clearance between the beadlock ring and brakes. Any help would be greatly appreciated Thanks
"IT IS WHAT IT IS"
PostPosted: Sun Dec 04, 2011 8:15 pm
Most people run Willwood 4 piston calipers and they work very well. I personally use Jamar and they work great but they are pricey.
PostPosted: Sun Dec 04, 2011 8:32 pm
Yea, The deciding factor is going to be the caliper size/heighth off of the rotor so it will clear my rim...
"IT IS WHAT IT IS"
PostPosted: Sun Dec 04, 2011 8:41 pm
I'll check my GM brakes here in a bit for you.
PostPosted: Sun Dec 04, 2011 9:58 pm
Im using wilwood dynalite 4 piston calipers its 1 inch bigger then the rotor.thats a safe height you probably get a little closer so it will be about 7/8 of a inch higher then the rotor. when I went to the canton swap meet last month I bought 2 of them for $20 each what a find :mrgreen:
PostPosted: Sun Dec 04, 2011 10:38 pm
The GM ones wont give you enough room, sorry.
PostPosted: Sun Dec 04, 2011 11:01 pm
I have a set of sentra calipers in the barn I'll measure tomorrow and send it to ya
PostPosted: Sun Dec 04, 2011 11:14 pm
grind the caliper down like they do on 4x4 if it is too large.... some are takin a lot more off them than you would think just depends on the caliper
if it aint broke don't fix it
PostPosted: Sun Dec 04, 2011 11:27 pm
True I used to grind a ford Dana 60 caliper to fit a fifteen inch wheel , swoooo it was alot of grinding though lol
PostPosted: Mon Dec 05, 2011 2:12 am
x2
just make sure its a steel caliper if you go this route, i dont think aluminum like the cnc and wildwoods would hold up if ground down very much if any at all
PostPosted: Mon Dec 05, 2011 12:57 pm
I figure the wilwoods were pretty low profile, Appreciate you guys helpin with this :mrgreen:
"IT IS WHAT IT IS"
