It is currently Mon May 04, 2026 8:36 am
 Post subject: my project car
PostPosted: Fri Jan 04, 2013 7:55 am
Image 1988 camaro v6 5spd as of now got a 383 stroker for it and a v8 t5 with hooker comp headers and a full flowmaster 3in exhaust with 40 series muffler to go on soon 12 in aluminum slots for the back and 8's up front undecided on the color im thinkin a tangerine orange!!
 Post subject: Re: my project car
PostPosted: Mon Jan 07, 2013 4:32 pm
I had a 82 fire bird with a 327 and put a muncie 4 speed in it and had problems back then coming up with some way to hook up the arm that runs from the rear end to the transmission. Did you have any issues with that.
PostPosted: Mon Jan 07, 2013 9:42 pm
No I won't have that problem cause I have the clamshell mount that mounts the torque arm 85 up has that arm
PostPosted: Mon Jan 07, 2013 10:10 pm
best thing to do with the torque arm is pitch it and put a ladder bar or 4-link under it. best motor ive seen in a camaro was destroked 400 small block makes a 373 torque monster. if you plan on launching this thing hard and often id sugest frame tying the hell out of it or a 6 point cage if not it will start to wrinkle and crack behind the windows. your one step ahead of the game with the v6 springs in the front there longer and softer which preloads them more. preload equals more weight transfer to the rear when you launch it. with 400hp and a rear suspension that will hook you should have no problem running in the 10 second range play with your torque converter stall and gear ratio to get the motor to peak as you cross the line you might be able to see high 9s.
PostPosted: Mon Jan 07, 2013 10:16 pm
sorry i just noticed you dont have a torque converter so my next bit of advice is to sell that t5 and get you a th350 automatics are SO MUCH FASTER. every time you push that clutch your not accelerating an auto on the other hand gives you a burst of acceleration everytime it shifts.
PostPosted: Tue Jan 08, 2013 12:55 am
I have a 350turbo that's all built. But I'm not gonna race it its just gonna be my summer driver I got a Lil one now so racin isn't in my future :mrgreen: but thanks for all the helpful info I love shifting through the gears hearin the exhaust as u wind it up plus havin 2 extra gears over the 350 turbo will sure help on the fuel bill :mrgreen:
PostPosted: Tue Jan 08, 2013 12:58 am
Be a fun ride. Id end up in jail .
PostPosted: Tue Jan 08, 2013 1:13 am
Yea it'll be fun :mrgreen: I just hope that it don't land me in jail cause its gonna Be hellish loud especially with no emissions in this county :D
