New Haspin Hauler...
http://woodsbuggy.com/phpBB3/viewtopic.php?f=9&t=11850
Author:  lngtrvl2332 [ Wed Jun 08, 2011 8:54 am ]
Post subject:  New Haspin Hauler...
I kinda put the carriage before the horse in this hobby since all I own for a truck is a v6 ranger that barely pulls a cap and ladders. I have been keeping an eye out for a cheap truck built for pulling and I came across this...
1989 Ford F-250 4x4
127,000 mi.
5th wheel and 1+ ton rear spring conversion
12,000 lbs rear reese
460 cu inch EFI
5 speed MANUAL with OD (yes I know ford autos aren't worth their weight in scrap)
Tilt, AC, Cruise, Dual Tanks (needs 'em)
410 gearing with traction lock
Cab and corners are solid. Just the typical fender rust. Color was even right. I think some luggy E-range 35" tires and some bushwackers to distract from the piss poor color match on the fender wells and I got a reliable truck to pull anything I need. Not bad for $1,800.
Author:  Rick [ Wed Jun 08, 2011 11:07 am ]
Post subject:  Re: New Haspin Hauler...
id say you done well!
Author:  nitro_mudder [ Wed Jun 08, 2011 9:59 pm ]
Agreed, should do the trick.
Author:  ridenrace6 [ Fri Jun 10, 2011 12:14 am ]
hard to beat a ford, unless of course dodge made it and cummins shakes it :mrgreen:
Author:  Pugsley [ Fri Jun 10, 2011 2:49 am ]
Hey... you should show that high dollar after market fuel pump relay they installed! :shock:
Author:  lngtrvl2332 [ Fri Jun 10, 2011 8:32 am ]
Why would anyone want to trust an un-reliable old OEM relay??? A jumper made out of a rusty paperclip is far superior.... in CUBA :roll:
Author:  lngtrvl2332 [ Fri Jun 10, 2011 8:41 am ]
One of the people I mow for has a '64 F-250 4x4 with a Cummins conversion (done nicely). That's enough to make us both jealous. :D
Author:  ridenrace6 [ Fri Jun 10, 2011 2:38 pm ]
that would be the best truck on highway hands down if ford and cummins would get together 8)
