It is currently Tue May 05, 2026 5:05 am
 Post subject: Fuel Injection for turbo
PostPosted: Wed Jul 14, 2010 11:57 am
For sale is a Tim's System Fuel Injection that is designed for turbo applications but can be used in non turbo system. This system can adjust Idle, Mid, Top, TPS, Accelerator, Boost start and Boost Quantity. There is also another controller for Boost Enrichment with a Boost control and Quantity control. This controller is used to add a second set of injectors to inject alcohol or methanol during boost. They are 55lb injectors with a CB Performance Fuel Injection pump. Also included is the boost sensitive fuel pressure regulator and intake plenum for IDF manifolds. This system worked very well for me. I would be interested in a partial trade for a set of Weber 44's with linkage. If you have any questions call, text at 724-494-7405 Thanks for looking, Dave
