It is currently Tue May 05, 2026 3:37 am
PostPosted: Mon Jul 19, 2010 11:18 am
A friend of mine bought a buggy this past week. Tore the block down to do bearings and found a bent rod, piston skirt with some breakage and a jug with a small 1/4 chunk out of it. The block will clean up
He is needing a matching 1600 jug and piston, standard rod, and some stock pedals. Anyone have any laying around, cheap?
Thanks, Eggman
