New 1915cc Engine
http://woodsbuggy.com/phpBB3/viewtopic.php?f=7&t=9863
Author:  turboblue [ Fri Jul 09, 2010 5:57 pm ]
Post subject:  New 1915cc Engine
All brand new, never fired.
1915cc Longblock
*Aluminum case
*chromoly head studs
*8:1 compression
*CB 69mm counterweight/8 dowel/ forged crank
*CB Unitech rods "I beam"
*Engle 110 cam
*CB straight cut gears
*Scat lifters
*30mm heavy duty oil pump
*3.5 oil sump
*94mm cima piston kit
*Steve Tims 42x37 ported/polished heads.
*Scat solid shaft rockers w/ Scat swivel foot adjusters
*Scat moly gland nut
*lightened flywheel 8 dowel
*drilled for full flow with steel pump cover w/ fittings
*stock valve cover & bales drilled for breather box
* $2200 OBO
Author:  turboblue [ Tue Aug 03, 2010 11:13 am ]
Post subject:  Re: New 1915cc Engine
Bump
Someone needs this........ 8)
Author:  woogiebugger1 [ Tue Aug 03, 2010 12:42 pm ]
Are these drilled valve heads? :lol:
Author:  turboblue [ Tue Aug 03, 2010 2:58 pm ]
Give me $2200 and I'll tell ya...... 8)
Author:  woogiebugger1 [ Wed Aug 04, 2010 1:38 pm ]
I should have. I've already got 3300.00 in this new 2110. Damned. You've got a good buy there at what your asking. And mine doesn't even have drilled valves yet!!!!
Author:  turboblue [ Fri Oct 08, 2010 2:21 pm ]
Pending..........finally.......... :mrgreen:
Author:  turboblue [ Tue Oct 12, 2010 11:53 am ]
She's gone..........bye, bye........ 8)
