It is currently Mon May 04, 2026 9:28 am
 Post subject: New 1915cc Engine
PostPosted: Fri Jul 09, 2010 5:57 pm
All brand new, never fired.
1915cc Longblock
*Aluminum case
*chromoly head studs
*8:1 compression
*CB 69mm counterweight/8 dowel/ forged crank
*CB Unitech rods "I beam"
*Engle 110 cam
*CB straight cut gears
*Scat lifters
*30mm heavy duty oil pump
*3.5 oil sump
*94mm cima piston kit
*Steve Tims 42x37 ported/polished heads.
*Scat solid shaft rockers w/ Scat swivel foot adjusters
*Scat moly gland nut
*lightened flywheel 8 dowel
*drilled for full flow with steel pump cover w/ fittings
*stock valve cover & bales drilled for breather box
* $2200 OBO
 Post subject: Re: New 1915cc Engine
PostPosted: Tue Aug 03, 2010 11:13 am
Bump
Someone needs this........ 8)
PostPosted: Tue Aug 03, 2010 12:42 pm
Are these drilled valve heads? :lol:
PostPosted: Tue Aug 03, 2010 2:58 pm
Give me $2200 and I'll tell ya...... 8)
PostPosted: Wed Aug 04, 2010 1:38 pm
I should have. I've already got 3300.00 in this new 2110. Damned. You've got a good buy there at what your asking. And mine doesn't even have drilled valves yet!!!!
PostPosted: Fri Oct 08, 2010 2:21 pm
Pending..........finally.......... :mrgreen:
PostPosted: Tue Oct 12, 2010 11:53 am
She's gone..........bye, bye........ 8)
