It is currently Mon May 04, 2026 9:06 am
PostPosted: Sun Mar 28, 2010 12:58 pm
This engine was built new in spring of 08 and has had very little use since then. It was built from a standard vw german case. Bernie Bergman 82mm crank, Engle 110 cam,Mofoco big valve heads,hardened pushrods, dual 44 weber carbs, full flow oil system tapped from the front of the engine, and also uses the stock oil cooler, so you have 2 oil coolers and 1 oil filter for increased oil capacity, new bosch alternator,all chrome, Bosch 009 dist, and new blue coil,bolt on valve covers, crankcase ventilation system. It comes with a Kennedy stage 2 pressre plate and kushlok disc. Spent around 5000.00 on this engine. Runs excellent. 2500.00 firm. 662-665-1995.
