It is currently Mon May 04, 2026 9:00 am
PostPosted: Fri Feb 26, 2010 6:36 pm
I got my taxes back and now I feel compelled to stimulate the economy! I am looking for parts to finish my rail build. I can either pick up, or meet at Buggy Builders if you have what I need. I am also happy to pay for shipping if necessary.
1-Coilovers, Fox, King, Sway-a-way. NOT EMPI or the other fake coilovers
2-Torsion eliminators-the pieces that replace the spring plates and torsion bars when converting to coilover.
3-Link pin trailing arm bushings
4-Rack and pinion with tie rods
5-wheels- set of 4, spindle mount fronts, and 15 X 8 or 10", 4 lug rears
6-brake lines and hoses
7-Clutch line tubing, for CNC master and slave cylinders
8-Shift rod, stock VW will work, I can modify.
9-Exhaust 1-1/2". Not particular on style, Ceramic preffered
10-200mm Clutch disc, Kush-lok or simalar
11-200mm Pressure plate, KEP Stage 1
I prefer new or like new condition. Thanks in advance.
Check out www.Thegoodvolks.com!
PostPosted: Fri Feb 26, 2010 7:10 pm
I got off road rack and pinion used one ride $100.00 thanks also got some rims 8 or 10 look like wagon wheels $120.00 for all
PostPosted: Fri Feb 26, 2010 7:18 pm
I have aluminum front spindles with new bearings. For KP spindles.
PostPosted: Fri Feb 26, 2010 10:31 pm
I have a 1 time ran pressure plate stage 1 run it once at east lyne now im running a stage 2 4 my bigger motor.75.00 still have box it came in.
PostPosted: Thu Mar 25, 2010 11:30 pm
Still looking, I'll be at Buggy Builders this Sunday! I have parts to trade also!
