It is currently Tue May 05, 2026 1:17 am
PostPosted: Sat Feb 20, 2010 10:35 pm
Looking for a rear disc brake conversion. Currently running wide 5 bolt pattern wheels. Would like to avoid getting different wheels unless needed. Also looking for cutting/turning brakes aswell. If anyone can help with my project please let me know.. Tks
PostPosted: Mon Feb 22, 2010 9:42 am
What are wanting to pay. There is kits avalable from 200 on up to 2000. The 200 dollar kits are your typical China cast rotor hubs with cast calipers. 300 dollars with emergency brake option. Jamar, CNC, Gear one etc, all use Billit hub and calipers with 1/4" or 5/16" bolt on rotors. These kits start off at about $650.00
PostPosted: Mon Feb 22, 2010 12:48 pm
I bought a $500 or so kit a few yrs ago, and wish I hadnt. You can buy the rotors seperatly, and then get whatever kind of calipers you want. You will have to make brackets for the calipers and cutter levers. Alot of it depends on your fabricating abilities and what type of calipers you want to run. Pretty much any type of caliper can be made to work. The Wildwoods seem to be the best from what everyone on here says.
