It is currently Mon May 04, 2026 7:40 pm
PostPosted: Fri Apr 09, 2010 1:08 am
Engine kept running hot, finally figured out there was exhaust leaking into the coolant. Took the heads off the gaskets were shot. Put new gaskets on still doing the same thing. Heads probably need repaired. Don't know a lot about engines. Thinking of starting over and going ecotec. All the adapter stuff is worth at least 15; only ran it for a month.
comes with
adapter plate/flywheel
chrome bracket for alternator
wiring harness
I live in Hartselle AL 35640 Name's Eric 256-466-3972
PostPosted: Fri Apr 09, 2010 10:45 pm
how about selling the adapter , the ecu, and wireing harness???
lets just ride
