It is currently Mon May 04, 2026 6:24 am
PostPosted: Thu Jan 14, 2010 8:09 pm
THIS CRANK IS A 90 MM FULL CICRLE WEDGEMATED CRANK FROM DPR .IT ALSO COMES WITH CB PERFORMANCE 5.7 H-BEAM RODS FLYWHEEL IS 12 LBS AND IS WEDGEMATED WITH THE CRANK . I BOUGHT THIS SETUP FOR OVER $1100.00 I WILL SACRIFICE IT FOR $850.00 PLEASE HURRY IM IN A BIND AND NEED THE MONEY CONTACT ME HERE OR AT MY PHONE 205-389-7840 obo.
PostPosted: Sun Jan 17, 2010 12:34 am
any offers
PostPosted: Sun Jan 17, 2010 11:48 am
New or used?
PostPosted: Sun Jan 17, 2010 12:40 pm
it is lightly used i have another 2500 i run this was going to be a back up motor for my gf and she decide to go water cooled . it was ran about three weekends by her .i just it got back from dpr i had them inspect and polish the journals its flawless and i will garuntee that its good.
PostPosted: Sun Jan 17, 2010 2:16 pm
is it std .010 or :?:
PostPosted: Sun Jan 17, 2010 3:08 pm
all dpr cranks comes in .010
PostPosted: Sun Jan 17, 2010 4:02 pm
Ive left 2 messages on the # you provided and sent you a PM.If you still want to sale this stuff get up with me.My PH# is 513-939-6375.
PostPosted: Tue Jan 19, 2010 6:46 pm
What happened to the KID,did he disappear?
PostPosted: Tue Jan 19, 2010 8:06 pm
Not on the rod journals.
PostPosted: Thu Jan 21, 2010 4:42 pm
I thought all cranks including DPR has the standard size and then go .010" if needed to be regrounded and polished some, I think all new cranks are standard sizes on the main journals and the rods as well. If so, why do they come .010" new???
PostPosted: Thu Jan 21, 2010 8:55 pm
Turbo they come std on rods & .010 or.020 on mains right ?
PostPosted: Thu Jan 21, 2010 9:45 pm
Turbo they come std on rods & .010 or.020 on mains right ?[/quote][/quote]
yes they come std on the rods and they come .010 on the crank just to be safe after all the machine work the ods are turned down to chevy journals at the end so no need to turn them to .010
PostPosted: Fri Jan 22, 2010 7:15 pm
So i guess you dont want to sale this stuff or you just want to act like you do.If you dont want to accept what i offered then tell a man something instead of making him wonder and sit on here typing messages to you and get no awnsers.If you want $850,then say that,dont put O.B.O..
PostPosted: Fri Jan 22, 2010 7:24 pm
Right.
They are submerged arc welded on the rod journals then offset ground to 2.000" for the Buick sized bearing.
Everyone calls them a Chevy journal but they actually take a bearing that is for a Buick.
CB610P is the Clevite part number.
PostPosted: Fri Jan 22, 2010 7:48 pm
hey turbo,there is a guy here that uses rods out an olds quad four motor.he's got more time and money than most,he has built some awsome stuff over the years.chad :mrgreen:
PostPosted: Fri Jan 22, 2010 9:00 pm
If i offer you $850 will you give a man an awnser :?: :?: :?:
