| Heads and carbs http://woodsbuggy.com/phpBB3/viewtopic.php?f=7&t=8301 |
| Author: | turboblue [ Wed Dec 23, 2009 2:41 pm ] |
| Post subject: | Heads and carbs |
These are welded ported VW heads, matched intakes, dual 44 IDF carbs, filters and crossbar linkage. One plug hole has been inserted. Came off a 2332cc woods buggy engine. Customer is now going turbo. Pretty dirty but overall in decent shape. All this belongs to the turbo customer. $750 firm for the package. ![]() ![]() ![]() ![]() ![]()
| Author: | ironhorse [ Fri Jan 01, 2010 5:16 pm ] |
| Post subject: | Re: Heads and carbs |
are those the same size in the heads it doesnt look llike it |
| Author: | turboblue [ Sat Jan 02, 2010 11:14 am ] |
ironhorse wrote: are those the same size in the heads it doesnt look llike it I dunno, let me check. These belong to a customer. I was just trying to help him sell them. |
| Author: | hauser2169 [ Thu Jan 14, 2010 3:13 pm ] |
how much for carbs |
| Author: | gasman [ Thu Jan 14, 2010 3:47 pm ] |
it does look like two diffrent sizes.might just be one of those pictures,but looks diffrent.how much have these been run,do you know? |
| Author: | dunebuggynut [ Thu Feb 04, 2010 2:34 am ] |
Gary, Ive been looking at these to run on a 2180 I got cheap. I can get thick wall cylinders & cut the bottom to 92mm since the heads are 94mm. Question is that upper head looks like it has 40x35.5 valves & the lower one looks to have 42x37's in it. Am I wrong??? |
| Author: | giveitagallon [ Thu Feb 04, 2010 7:35 am ] |
dunebuggynut wrote: Gary, Ive been looking at these to run on a 2180 I got cheap. I can get thick wall cylinders & cut the bottom to 92mm since the heads are 94mm. Question is that upper head looks like it has 40x35.5 valves & the lower one looks to have 42x37's in it. Am I wrong??? did you get the 2180 from a guy in east liverpool ?
| Author: | dunebuggynut [ Thu Feb 04, 2010 9:38 am ] |
giveitagallon wrote: did you get the 2180 from a guy in east liverpool ? Yea, thats the one. Its a newer mag case. The bottom end is tight & was recently freshened up. The cylinders are junk. They were honed & ringed once so Im gonna replace em. Heads are nothing special & were probably restricting it 35 or more HP. The DIS IX ignition is new & I may try it. I have another one thats new for a spare. The dual carbs will go on something else. I think they were holding it back as well. |
| Author: | turbo2332 [ Thu Feb 04, 2010 4:09 pm ] |
hey guys these are my heads and carbs. i ran this set-up for over three years. never a problem. yes we just found out that for some reason the valves in one head are different? these came off a very healthy 2332 and never had an issue with them. |
| Author: | jackson.ryan29 [ Tue Feb 16, 2010 8:25 am ] |
do u still have the heads and how much for them |
