It is currently Mon May 04, 2026 2:19 am
PostPosted: Thu Jan 08, 2009 10:29 pm
Looking for a stock dp motor or maybe w/87mm or 88mm p/c. Also need some used rear tires in good shape 31x12x15? (12"wide rims) Ive got a buggy for my dad that i need to get done by april and i need to find this stuff. Preferably local pickup, NE ohio. Thanks Jason
PostPosted: Wed Jan 14, 2009 12:23 am
This is for a buggy im buikding for my dad, and i dont have much money. I have a buggy already that im pumping money into so i need to build a budget buggy. I have a frame with a swingaxle drum to drum(keeping it), front end, steering wheel w/shaft,lights, front rims and tires, rear rims. I need a running motor or a stock case,have 87 p/c stock heads, oil pump,valves,cam shaft w/gear.So i still need lots of stuff,seats,motor parts, oil cooler, rear tires(29x12.5x15). Thanks for the help in advance. Im in N.E Ohio. Jason
PostPosted: Wed Jan 14, 2009 4:08 pm
what kind of front end you looking for k/p or b/j. my bother has a frame that's no good with b/j front 2 seats lights,
steering shaft no tires or rims has cutter, stock peddals
PostPosted: Wed Jan 14, 2009 5:58 pm
Is the B/J in good condition? I might need one
PostPosted: Wed Jan 14, 2009 10:22 pm
bought from jims last may it was rebuilt by them. paid 240 for it might take 150 have to check with him will do that tomorrow. he is on the boat so i can't talk to him until then, will take some photos of it then to try to post
PostPosted: Thu Jan 15, 2009 9:41 pm
Dont need a front end Andrew, need some rear tires, seats, good block or complete motor, oil cooler. If I get a block then i need motor parts(crank,cam,rods,etc....)Let me know. Thanks Jason
