axles
http://woodsbuggy.com/phpBB3/viewtopic.php?f=7&t=5209
Author:  cyle [ Mon Dec 01, 2008 7:54 pm ]
Post subject:  axles
where can I get torsional 930 axles they need to be 19 1/4.
Author:  Firebug [ Mon Dec 01, 2008 9:47 pm ]
Post subject:  Re: axles
http://cgi.ebay.com/ebaymotors/Dune-Bug ... ccessories
Author:  Firebug [ Mon Dec 01, 2008 9:48 pm ]
http://dansperformanceparts.com/cgi-bin ... gory_Code=
Author:  cyle [ Mon Dec 01, 2008 10:12 pm ]
Thanks for the help firebug
Author:  Firebug [ Mon Dec 01, 2008 10:19 pm ]
I cant vouch for the torsional part,,ask them ,,but I run the Dans axles with no problem,,the others are cheaper. Make double sure you are ordering the correct length.,,,,You can shorten them a dab if necessary with a chop saw. good luck
Author:  cyle [ Tue Dec 02, 2008 7:47 pm ]
What kind of 930 cv's do you use.
Author:  Baddvw [ Tue Dec 02, 2008 8:46 pm ]
Get a set from Quicksand Performance, they make a good set of 930 cv's cheap, it will be a good set for the setup you have, but if you go big power and torque, I would rather run Lobro's and SAW axles from K-1 Kustoms. I tore up my CV and axle this past May at the Cold Spot and was running it very hard.
