It is currently Mon May 04, 2026 2:12 am
 Post subject: axles
PostPosted: Mon Dec 01, 2008 7:54 pm
where can I get torsional 930 axles they need to be 19 1/4.
 Post subject: Re: axles
PostPosted: Mon Dec 01, 2008 9:47 pm
http://cgi.ebay.com/ebaymotors/Dune-Bug ... ccessories
PostPosted: Mon Dec 01, 2008 9:48 pm
http://dansperformanceparts.com/cgi-bin ... gory_Code=
PostPosted: Mon Dec 01, 2008 10:12 pm
Thanks for the help firebug
PostPosted: Mon Dec 01, 2008 10:19 pm
I cant vouch for the torsional part,,ask them ,,but I run the Dans axles with no problem,,the others are cheaper. Make double sure you are ordering the correct length.,,,,You can shorten them a dab if necessary with a chop saw. good luck
PostPosted: Tue Dec 02, 2008 7:47 pm
What kind of 930 cv's do you use.
PostPosted: Tue Dec 02, 2008 8:46 pm
Get a set from Quicksand Performance, they make a good set of 930 cv's cheap, it will be a good set for the setup you have, but if you go big power and torque, I would rather run Lobro's and SAW axles from K-1 Kustoms. I tore up my CV and axle this past May at the Cold Spot and was running it very hard.
