It is currently Sun May 03, 2026 4:10 pm
 Post subject: Custom pan and parts
PostPosted: Sun Jul 06, 2008 9:11 pm
I'm thinking about giving up my project. Its a baja I've been slowly building. The pan was going to have an a arm front end. I haven't done the front of the pan due to not having all the parts like the steering rack. The pan is built for a 3 in ch body lift. I have welded the frame horns and clearanced them for a midshift trans. I haven't built a mount for the midshift trans yet. If someone buys the pan I'll make them a package deal with the rest of the parts I have. I will not sell anything unless the pan goes. I also have a 74 std body that I cut the roof off of. Its rusty but I was planning on doing a full tube chassis so I was only using it as bodywork. I have 2 84-85 midshift transmissions that are supposed to be good. I also have another one with a bad 3/4 shift fork. I have a pair of 924 stub axles, 3 76-79 bus axles with cvs. I've got some other type 2/4 cvs as well for spares. I've got 4 brand new wheels. 15x5 and 15x8. I've got two 235x75r15 used bfg allterrains for the fronts. I've got two modified 914 uprights that I was going to use as spindles. I've got the top inserts turned out but not the lower. I have 1in with 1.25 shank hiems with high misalignments for the lower pivots. I only have 1 3/4 for the upper with high misalignments. I will sell either the pan and body or the whole package. $400 firm for the pan and body. $1500 firm for everything. More pics of anything are available upon request.
John
256-479-1526
 Post subject: Re: Custom pan and parts
PostPosted: Sun Jul 06, 2008 9:34 pm
PostPosted: Sun Sep 07, 2008 2:47 pm
Still for sale. Price drop. $300 for the pan. $1300 for everything.
PostPosted: Sun Nov 02, 2008 12:20 am
$1200 for everything. If I can't get that, I'll just keep it.
John
