It is currently Tue May 05, 2026 2:52 am
PostPosted: Thu Sep 11, 2014 9:00 pm
Hey guys time to clean up a bit I have two engines and two trans axels for sale
2054 Stroker complete Asking $1800
Brand new crank
Brand new Chromoly H-Beam rods
Engle W 110 Cam with steel on steel straight cut gears
040 Mofco heads, with 1.25 ratio rockers
Eight dowl flywheel
Dual 40 EMPI carbs bought new not old rebuilt
Full flow oil pump
Remote filter and cooler
Engine also has stock cooler ,it is double cooled
All parts except engine case were bought new this engine runs great lots of power
1915 bottom end including piston and jugs no heads Asking $500
counter weighted crank
Lightened eight Dowel flywheel
Engle W 110 Cam
Full flowed block
I have a 5 rib and 3 rib, the 5 rib is fresh rebuilt never put back in buggy
asking $500 for the 5 rib and $200 for the 3 rib
2008 Honda TRX90 only rode around yard and driveway never been in the woods Asking $1800
Will post pics of anything you guys are interested in
PostPosted: Thu Sep 11, 2014 9:24 pm
Where you located? Id like the trannys if your close to cincinnati
PostPosted: Thu Sep 11, 2014 9:32 pm
I am located in southeast Ky. would be willing to meet around Lexington Ky. on a Saturday
PostPosted: Thu Sep 11, 2014 10:31 pm
Good deal. Ill take both trannys. Im leaving for rush tomorrow so ill be gone all weekend.unless you wanna meet me over there. Whats up with the 3 rib
PostPosted: Fri Sep 12, 2014 1:28 pm
The three rib is good it was pulled from a buggy to put a six rib back in I have a good friend going to rush today I can send them with him
PostPosted: Fri Sep 12, 2014 1:41 pm
Diamond Dave I am going to send those trannys to rush with BOO-BOO, Darrel knows him so you shouldn't have any trouble finding him Thanks
PostPosted: Fri Sep 12, 2014 2:16 pm
Cool man. Thanks.7 crisp hundreds will find there way back to you:mrgreen:
PostPosted: Tue Oct 28, 2014 9:47 am
Do you still have the engines?
PostPosted: Thu Oct 30, 2014 8:25 pm
Yes I do still have the engines
PostPosted: Mon Nov 03, 2014 10:22 pm
PostPosted: Mon Nov 03, 2014 10:29 pm
PostPosted: Mon Nov 03, 2014 10:30 pm
Here is both engines guys hope it helps
PostPosted: Wed Nov 05, 2014 12:52 am
Give me a call on the 1915 513 833. 3277
PostPosted: Thu Nov 06, 2014 7:49 pm
Hey Darrell Scott tells me that he is coming your way this weekend if you would like I can send the 1915 with him
PostPosted: Sat Jun 27, 2015 8:10 pm
asking $1500 if anyone interested those are original tires I think it's a 2009 or 10 not sure right off
PostPosted: Sat Jun 27, 2015 9:15 pm
It is a TRX 90
PostPosted: Tue Jun 30, 2015 6:42 pm
Is the stroker still available?
PostPosted: Tue Jun 30, 2015 8:14 pm
No sorry 1915 sold trans have sold and the stroker I put into my 73 super beetle
PostPosted: Tue Jun 30, 2015 8:15 pm
PostPosted: Tue Jun 30, 2015 8:17 pm
Update TRX 90 is a 2008 was only rode by my son in the yard
