PostPosted: Tue Feb 17, 2015 5:18 pm
Hello everyone,
We're starting our MBB show specials early this year! Now is the time to swap to an Ecotec or Turbo your current setup! YOU MUST order before MAR 14 to recieve the special discounts and/or free shipping incentives. We can also coordinate pickup at the show! In fact, we sold out of engines at the show - don't wait!
AFI STAGE I Ecotec Combo's come with the following accessories and are priced as follows: $2280 + 25% discount on shipping. Regular $2400 + shipping.
1. AFI Ecotec 2.4 VVT engine [used] w/ intake manifold & throttle body
2. Exhaust manifold w/ O2 Sensor
3. All needed electronic sensors [coils, cam sensors, knock sensor, VVT, etc.]
4. Fuel rail & injectors
5. AFI Billet Adapter Plate & Flywheel [8" or 9"]
6. AFI Engine Harness, ECM, & Performance Tune
8. AFI DBW Pedal
9. AFI Intake Air Temp. Sensor [needed for harness]
See pictures and more info here:
http://www.alphafabindustries.com/colle ... swap-combo
AFI STAGE II Ecotec Combo's come with the following accessories and are priced as follows: $2540 + 25% discount on shipping. Regular $2675 + shipping
8. AFI DBW Pedal
10. AFI Billet water neck block off
11. AFI Billet -6AN fuel rail adapter
12. AFI Billet Oil Pressure relocation kit
13. All parts & accessories installed!
See pictures and info here:
http://www.alphafabindustries.com/colle ... o-stage-ii
AFI STAGE III Ecotec Combo's come with the following accessories and are priced as follows: $2850 + 25% discount on shipping. Regular is $3000 + shipping.
8. AFI DBW Pedal
13. New GM Remanufactured 125 AMP Alternator
14. GATES Micro-V Serpentine belt
15. All parts & accessories installed!
See more info at pictures here:
http://www.alphafabindustries.com/colle ... -stage-iii
AFI STAGE IIII Ecotec Combo's come with the following accessories and are priced as follows: $3450 + 25% shipping discount. Regular is $3650 + shipping.
2. AFI Long-tube Header w/ O2 Sensor
8. AFI DBW Pedal
15.AFI EFI Fuel pump [supports 65 PSI]
16. All parts & accessories installed!
See more info and pictures here:
http://www.alphafabindustries.com/colle ... stage-iiii
This is a complete bolt-in solution with the large primary pieces needed to properly install your Ecotec! All you need is a radiator, fittings, and hoses!
See Stage 4's in action here!!!
Want more power? We have that too! We've developed 3 Stages of off-road based turbo kit packages - rated from 250-400+ RWHP. Our turbo kits were developed so that our customers could grow power levels with time/budget/transmission!
Our AFI 2.4 ECOTEC STAGE I TURN-KEY ENGINE & TURBO KIT PACKAGE: $5975 + 25% shipping discount, Regular $6300 + shipping
STAGE I 2.4 LE5 Turnkey Package, 300 HP:
* AFI 2.4 Ecotec VVT Engine w/ all needed sensors, AFI ceramic coated turbo exhaust manifold w/ O2 sensor, USED crate engine equivilant, bench tested, race prepped, cleaned, assembled, and AFI QC
* AFI Harness & ECM System, OBD2 compliant, configured for electronic drive by wire throttle [cable throttle available upon request]
* AFI Billet -6AN Fuel rail adapter
* AFI DBW Pedal
* AFI Intake Air Temperature Sensor
* AFI Stage I Turbo kit: Includes AFI turbo manifold [ceramic coated], GT28 Ball-Bearing turbo w/ v-band exhaust, Tial 38mm external wastegate [we can dump this back into exhaust if needed, ALL needed oil fittings, lines, and gaskets, ALL needed oil drain fittings, lines, gaskets, and oil pan modification, ALL needed water feed and drain fittings, lines, and adapters, Siemens 60" injectors, GM 2-BAR MAP Sensor, AFI Top Mount Air to Air Intercooler option w/ all piping, painted mount, silicone couplers, and Tial 50MM blow off valve, high flow air filter, AFI ECM STAGE I tuning, and all nuts, bolts, gaskets, etc.
Our AFI 2.4 ECOTEC STAGE II TURN-KEY ENGINE & TURBO KIT PACKAGE: $6400 + 25% shipping discount, Regular $6800 + shipping.
STAGE II Turnkey Package, 350HP Kit:
* AFI DBW Pedal
* AFI Stage II Turbo kit: Includes AFI turbo manifold [ceramic coated], GT28 Ball-Bearing turbo w/ v-band exhaust, Tial 38mm external wastegate [we can dump this back into exhaust if needed, ALL needed oil fittings, lines, and gaskets, ALL needed oil drain fittings, lines, gaskets, and oil pan modification, ALL needed water feed and drain fittings, lines, and adapters, Siemens 60" injectors, GM 2-BAR MAP Sensor, AFI Top Mount Air to Air Intercooler option w/ all piping, painted mount, silicone couplers, and Tial 50MM blow off valve, high flow air filter, AFI ECM STAGE II tuning, and all nuts, bolts, gaskets, etc.
Our AFI 2.4 ECOTEC STAGE III TURN-KEY ENGINE & TURBO KIT PACKAGE: $7400 + 25% shipping discounts, Regular $7800.
STAGE III Turnkey Package, 425 HP:
* AFI 2.4 Ecotec VVT Engine w/ all needed sensors, AFI ceramic coated turbo exhaust manifold w/ O2 sensor, USED crate engine equivalent, bench tested, race prepped, cleaned, assembled, and AFI QC
* AFI Harness & ECM System, OBD2 compliant, configured for, electronic drive by wire throttle [cable throttle available]
* AFI DBW Pedal
* AFI Stage III Turbo kit: Includes AFI turbo manifold [ceramic coated], GT30/35 Series Ball-Bearing turbo [determined upon order/turbo matching your needs] w/ v-band exhaust, Tial 38mm external wastegate [we can dump this back into exhaust if needed, ALL needed oil fittings, lines, and gaskets, ALL needed oil drain fittings, lines, gaskets, and oil pan modification, ALL needed water feed and drain fittings, lines, and adapters, Siemens 80# injectors, GM 3-BAR MAP Sensor, AFI Top Mount Air to Air Intercooler option w/ all piping, painted mount, silicone couplers, and Tial 50MM blow off valve, high flow air filter, AFI ECM STAGE III tuning, and all nuts, bolts, gaskets, etc.
See turbos in action here!!
Want a combo package you don't see? Just ask - we have supported and can support the L61 [early and late w/ individual coils], LSJ, LNF, LAF - naturally aspirated or boosted. It doesn't matter. These go fast!! Please call or email with questions!
All of our billet parts [adapters, flywheels, etc] are 10% off.
All of our harness / ECM combo kits are 10% off. We DO NOT sell harnesses seperately.
All of our lightbars are 20% off.
All our turbo kits are 5% off + free shipping.
Please call 734.794.3082 or email sales@alphafabindustries.com for questions or to place an order. These WILL go fast!
-AFI
PostPosted: Thu Feb 19, 2015 7:04 pm
Hey Shawn, whats the chance you guys are bringing the turbo'd nitrous motor you posted pics of on facebook to the show. Would love to check that motor out.
-Chris
PostPosted: Tue Feb 24, 2015 5:12 pm
-Chris
Hey Chris - I wish we could! It's currently being installed on a race boat! We'll have a couple Stage 2 turbo's you can check out!
-AFI
PostPosted: Mon Mar 23, 2015 4:03 pm
Get your kits now! We've got a couple folks picking up at the show!! Get your discount before it's too late!!
-AFI
