Stand alone Ecotec wiring harness 2.2
http://woodsbuggy.com/phpBB3/viewtopic.php?f=7&t=17297
Author:  Jeremy1 [ Mon Sep 01, 2014 5:06 pm ]
Post subject:  Stand alone Ecotec wiring harness 2.2
Stand alone harness all excess wiring trimmed out. All unnecessary emission and transmission codes deleted and most important vehicle theft deterrent system disabled. Harness comes labeled with a 5 wire hook up. Both cooling fan and fuel pump relays already wired in. Also check engine light. This will fit the earlier ecotecs the ones that have a cable operated throttle body. And a single coil pack on valve cover.330 442 5166. $350
Author:  Cush53 [ Mon Sep 01, 2014 10:22 pm ]
Post subject:  Re: Stand alone Ecotec wiring harness 2.2
No issues with mine and super easy installation thanks again jeromy
Author:  Jeremy1 [ Sat Sep 06, 2014 9:02 am ]
No problem Cush. I will headed to rush for the weekend can bring this with me if anyone is interested
Author:  720boy [ Sat Sep 06, 2014 9:12 pm ]
do you make them up or are you just have this one for sale thank's
Author:  Jeremy1 [ Sun Sep 07, 2014 7:36 am ]
I use a stock harness and trim all the extra stuff you don't need. Then I wire in the relays in so the ECM controls them like in the car. Then I flash the ECM with hp tunners. I have done these harnesses and sold them on woodsbuggy , the samba and eBay with no issues.
Author:  720boy [ Sun Sep 07, 2014 9:13 pm ]
do you do the newer ecotec motor,i have a 06 chevy can you do the harness for that one and how much thank's
Author:  bluebuggy [ Sun Sep 07, 2014 9:47 pm ]
If it's a 2.2 you can run it just need to change the TB to cable from wire drive. That's what I done works great.
Author:  Jeremy1 [ Mon Sep 08, 2014 7:48 pm ]
I can do the 06 give me a call and I can find out what exactly you are looking for.
