It is currently Sun May 03, 2026 1:20 pm
PostPosted: Fri Mar 14, 2014 5:51 pm
Hi Everyone,
We will be attending the Michigan Buggy Builder's Show next weekend in Lansing, Mich.
We plan to haul quite a few parts to the show, but we wanted to give you all on Woods Buggy the chance to reserve parts before we load the trailer at special pricing for WoodsBuggy.com members.
Below is a list of Woods Buggy Preorder Specials that we can deliver to you at the Michigan Buggy Builder's Show.
This will eliminate any shipping charges, which is a great deal for those who need large items.
Please note that quantities on some parts are limited so this will be first come first serve.
If you attend the show, please stop by and visit whether you are in need of any parts or not!
Now on to the parts:
 MSD Billet Distributor: $259
 Optima Red Top Dual Post Battery: $160
 Black Vinyl Racetrim Suspension Seats: $160 per seat.
 New HD LED light bars with Cree Bulbs, top quality, includes brackets and wiring harness
• 6'' Light Bar (above): $70
• 12" Light Bar (above): $125
• 20" Light Bar (above): $175
• 30" Light Bar: $275
• 40" Light Bar: $299
 Unisteer Electric Power Steering Kit: $650
 Scat Pro Car Terrain Suspension Seats in Black with slider rails: $170 per seat.
 Kennedy Pressure Plates, any stage: $99
 Sway-a-way Coilover Shock only, any length: $309 each
 IMI High Torque Starters (Car, 3 rib, 5 rib): $175
 IMI High Torque Starter (6 rib): $195
 AA Forged Stroker Cranks (69 mm to 82 mm): $225
 AA 94 mm x 82 mm Stroker Piston and Cylinder Kits: $159
 Mahle 94 mm x 82 mm Stroker Piston and Cylinder Kits: $340
 Drew's 2x3 Tubular Rear Trailing Arms: $375 per pair
 Firestone 31 inch Tractor Tire: $350 each
 Porsche 930 Axle Kit: $440
 Dual 40 and Dual 44 HPMX Carburetor Kit: $475
 New aluminum Auto Linea Bubbletop Aluminum Case (94 mm Bore, 7 mm raised deck, clearanced for 86 mm stroke, 10 mm case savers): $850
 All CNC Products: 10 percent off
 New 009 Distributors: $36
 Rear Disc Brake Kit (no e-brake): $199
 J&J Specialties VW 4 lug to wide 5 (5 x 10 1/4) wheel adapters, includes studs and nuts (above): $139 PR
 J&J Specialties lightened VW 4 lug to wide five (5 x 10 1/4) wheel adapters, includes studs and nuts (1 lb lighter per side):$159 PR
 New 60 Amp Alternator for Type 1: $85
 Bus to Bug Stub Axle, dual drilled for bus and bug bolt pattern:$75 PR + Exchange
 Home Plate Front Tire 590 x 15, great for the woods!: $100 each
 Beeline 98 inch ABS Plastic Body (Black or White), includes side and hood:$450.00
Let us know if you have any questions or need any other parts brought to the show and we will be happy to do what we can to make things happen!
To pre order call us at 513-868-9543, email webdrews@aol.com or pipe up on this thread!d
If you call please ask for Austen.
We will hold parts for all who make deposits! The rest will be first come first serve!
PostPosted: Wed Mar 19, 2014 10:43 am
How much on my homeplates shipped to 35956
Sent from my SCH-I605 using Tapatalk
PostPosted: Wed Mar 19, 2014 11:24 am
There is free shipping on our website for orders over $150.00 on UPS sized shipments so the homeplate tires will ship UPS and they are $114.00 ea. That is the best way for you to order them at the best price. WWW.GO-DREWS.COM They are in stock and can ship same day.
PostPosted: Wed Mar 19, 2014 11:49 am
$114 is that preorder special? cause your site says $142
PostPosted: Wed Mar 19, 2014 2:19 pm
Sorry about that. The update for the site just went through. It should show the Buggy Builder's Special now.
Cheers!
