It is currently Mon May 04, 2026 12:45 am
 Post subject: 1 piece rotor
PostPosted: Wed Aug 28, 2013 5:50 am
I need 1 or 2 of them. I bought 2 last Oct. and the splines inside one of them sheared completely off. More Chinese Cheese, but now I'm stuck with them and have to eat out of their hands. Speaking of Chinese Cheese (I bought this buggy), the thermostat on the oil cooler won't come on til the temp is 250 degrees. All this gagetry... I'll wire it direct tomorrow, the way it should be...
 Post subject: Re: 1 piece rotor
PostPosted: Wed Aug 28, 2013 8:59 am
Sounds like ye ole axle nut backed off thats what eats the chinese cheesee. :P :mrgreen: :twisted:
PostPosted: Wed Aug 28, 2013 11:35 am
No. It had the death grip on it. Just like every other axle nut I've tightened for over 35 years. The German factory stuff does not break near so easy.
PostPosted: Wed Aug 28, 2013 9:20 pm
I FOUND OUT WHY IT BROKE. Some 1 piece rotors have shorter splines and you have to run about 13/16th's of a spacer so the axle nut can tighten up against it. Make sure you buy the ones that DO NOT require a spacer. Now it should be about time for the other side to strip and I will be left dead in the woods again. Such joy! . :( They are only $80 plus. each). Plus you have a great day changing them out in your drive way.
PostPosted: Thu Aug 29, 2013 7:51 am
Like I said ye old nuts were lose
