It is currently Sun May 03, 2026 8:43 pm
 Post subject: 1915 3 rib and vw parts
PostPosted: Tue Jun 11, 2013 3:44 pm
im looking to sell all this as a package deal I don't want to sell separately sorry. I will still be running my buggy when I can and as you guys know ya need both to do so. its a long post so ill put the price up here wanting $2000 for everything I have listed I am going to install a 6 rib and 2.2 Subaru again this winter and figured id get a jump on trying to sell it thanks
motor:
1915cc
dual weber 44 carbs (made in spain)
empi linkage
bosch 009 distributor
electronic ignition
new plugs
new wires
8 dowell pin stock crank
new 40x35.5 heads single valve springs
newer 94mm jug and piston kit
lightened flywheel
new clutch
stock pressure plate
I want to say engle 110 cam if not then a vz15 cam sorry cant remember which he said
newer 1 wire alternator
newer stock fuel pump
power pulley for anyone curious
aluminum dog house
bolt on valve covers
stock rockers
spring loaded plastic pushtubes
may be something else I am missing motor runs good
3 rib trans is in good shape slides right into each gear nice, reverse works good also
the other parts I have:
2 blocks
2 empi 40 carb bodies no tops
1 weber 44 carb and intake froze up may be good core for something
1 set of empi dual intakes
1 set of unknown dual carb intakes looks like someone started porting them out
scat lifters and rockers some still in package may still be good
spare distributors 009 and vaccumm advanced
4 complete car axles cv to cv and also other car cvs have 12-15 car cv I do believe
new scat c-95 cam
miscellaneous gaskets and seals and lots of other small parts oil pumps, heads
set of eepco big valve heads cut for 94s they are cracked down by push tube hole but may be salvageable still never had them on a motor
new 88mm high compression mahle piston cyclinder kit
used mahle 94mm piston jug kit
there is a 90 or 92mm piston jug kit also in those parts I believe
oil cooler and remote oil filter will be left on motor when removed
PostPosted: Tue Jun 11, 2013 10:01 pm
Just throwing this out here do you guys think this is a fair price for everything or am I asking too much for it the case has very little end play and forgot to mention its an as-41 case which from what I read online its just a replacement case from what I was getting any input? Thanks
PostPosted: Wed Jun 12, 2013 4:18 pm
2k sounds about rite. Wish I had the cash. I would come get it today lol
PostPosted: Wed Jun 12, 2013 7:52 pm
x2 wish you posted this before i built my motor :|
