It is currently Mon May 04, 2026 6:22 am
 Post subject: NEED 6 RIB ASAP
PostPosted: Sun May 20, 2012 5:27 pm
LOOKN FOR A 6 RIB TRANNY JUST BUSTED MINE THIS WEEKEND ... PLEASE CALL 513 967-2741 ASK FOR TREVOR THANKS .....
BIG COUNTRY
 Post subject: Re: NEED 6 RIB ASAP
PostPosted: Sun May 20, 2012 10:05 pm
What did you break on yours?
PostPosted: Mon May 21, 2012 7:08 pm
i was there and sounds like a rod knocking when the trans is in gear even when its sitting still . when its not in gear no knock. :?
PostPosted: Mon May 21, 2012 7:52 pm
when you find out whats wrong with it please post on here. i have a buddy thats got one doing the same thing so he changed his trans and moter but used the pressure plate and throwout bearing on the new moter and now it sounds like it knocking also
PostPosted: Mon May 21, 2012 10:56 pm
Did you check the needle barings on the gland nut? And if its not that look to see if the pressure plate and the throw out baring mach up because there is a old and a new style. Hope that helps before you buy a new tranny
PostPosted: Tue May 22, 2012 9:40 am
yea travor was drag racing when the tranny broke. It was fine before that tho.
PostPosted: Tue May 22, 2012 4:27 pm
Drag racing is meant for drag cars when will we ever learn :roll:
PostPosted: Mon May 28, 2012 11:02 pm
he has got one now..... thanks pipedope the tranny worked great .
PostPosted: Tue May 29, 2012 7:24 pm
NO prob. did you drop that end mill off to Brian Drew?
PostPosted: Thu May 31, 2012 10:28 am
i called lisa they no i got it ....Going to drews today to drop it off .went to black mountin to ride this weekend il call ya later .
PostPosted: Fri Jun 01, 2012 11:30 am
Gave it to him today... he said thanks
PostPosted: Wed Jul 25, 2012 12:03 pm
Are you interested in selling the broken one?
