| 6 rib, with all close ratio gears http://woodsbuggy.com/phpBB3/viewtopic.php?f=7&t=12757 |
| Author: | wadeglisson [ Sun Dec 11, 2011 7:30 pm ] |
| Post subject: | 6 rib, with all close ratio gears |
I have a 6 rib that was run in a street buggy with a high compresson 1679. Transmission does not have a lot of use on it and is built for brutal punishment. All the needle bearings have been stacked by hand with no plastic retainers meaning that there is no up and down movement and will not let the gears separate under a load.It was built with all new German bearing including the pinion bearing and has had only synthetic oil used in it. It has a 3.55 first, I will post the rest of the ratios when I look them up tonight or tomorrow, a NOS German stock 091 was used in it, hardend shift forks, and the 4.56 ring and pinion that is in A1 condition. I do not want to sell this, but the injector pump is down on my dodge diesel truck and selling this will cover the repairs. I sold the buggy with a stock transmission because I have a ton in this transmission. I will take no less than 1500, or might even do a partial trade for some junk cars of any kind or old vw bus bodies. No jackers or time wasters wanted. The cars or the bodies can be junk, rusty, stripped, whatever, no titles needed. 662-665-1995 Transmission is in perfect condition! |
| Author: | RaceBugg1098 [ Tue Dec 13, 2011 1:23 pm ] |
| Post subject: | Re: 6 rib, with all close ratio gears |
where you at? what ratios? |
| Author: | wadeglisson [ Thu Dec 15, 2011 12:19 am ] |
I am in the northeast corner of MS The first gear is a 3.55 and I will find the sheet with the other ratios |
